AutoCAD Forum
AutoCAD license server not available - stand alone
5 REPLIES 5
bfriedman
396 Views, 5 Replies
Cannot connect to AutoDesk license server is unavailable. End user cannot use the Autodesk Suite 2015. HELP!
Tags (1)
5 REPLIES 5
sjoeyr
in reply to: bfriedman
Having the exact same problem...Please Help
DarrenP
in reply to: sjoeyr
did you try this: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Meta-licensing.html
DarrenP
bfriedman
in reply to: DarrenP
Yes tried that multiple times in the hope that the server would once again be available. It allows me to login then once again gets the license server not available.
bfriedman
It's working now. Not going to close and reopen as I don't want to find out if will reopen. We may never close it again.
sjoeyr
I ran all that was stated in the fix, then rebooted my computer, then I was able to open and run the program properly.
”Boost
