Hello everyone,
I desperately need some help with a project i am doing at the moment. im stuck on the following question:
For window W5 in bed 2, change the following:-
i) Width from 1780 to 1352mm about the same centre line.
ii) Depth from 1200 to 900mm keeping the same head.
Revise all associated parts of the drawing that are affected by this change,
updating title sheets and all affected drawing tabs.
I understand how to change the width of the window but cant work out how to change the depth. If someone could briefly expalin to me how to do this i could be VERY grateful.
Sounds like homework to me 🙂
There are no windows/doors objects in AutoCAD: all I see in your file are a bunch of lines representing walls, windows, and others, with some blocks.
Sadly, this is not the place to learn the basics of CAD and Architecture Drafting, it would take too long to teach you how to fix your drawing.
STRETCH command may be thew quick way to fix the "window": you need to talk to your "architect" about how that 'window' gets resized and how that is represented. Same with the walls.
As pendean was saying, yes, the stretch command will probably do the trick for you. Couple things to note though:
in the attached image i dimensioned the window to confirm what you are asking.
i changed the precision of the units and dimension style ABA-050
please try to show which dimensions you need to adjust
it sounds like a simple stretch command to accomplish both
