AutoCAD Forum
autocad hatch pattern
4 REPLIES 4
autocadding
1936 Views, 4 Replies
I want to create a hatch pattern of horizontal lines for a wall tile that follow this pattern:
first course - 200mm high
second course - 200mm high
third course - 300mm high
tile width - 600mm
can't figure it out - all the help pages online have explanations for incredibly complicated patterns with dashes / dots / zigzags.. you name it!
Can anyone recommend a good help page with simple step by step instruction to create a basic pattern of lines, then how to offset, then diagonals..
thanks!Smiley Happy
4 REPLIES 4
autocadding
in reply to: autocadding
Oh! I think I figured it out.. Let me know if there's a simpler way....
0, 0, 0, 0, 700
0, 0, 200, 0, 700
0, 0, 400, 0, 700
90, 0, 0, 0, 600
hugha
That's exactly right.
Edit:  Here's a tutorial on creating a brick pattern:
http://www.cadlinecommunity.co.uk/Blogs/Blog.aspx?ScoId=da5b7856-32cc-4f3c-a96a-bf7d9f880fe4
Creating simpler patterns - even with angled lines - follows the same principles but the arithmetic becomes tedious as pattern complexity increases.
Have a look at the simpler patterns (e.g AR-HBONE) in ACAD.PAT to work out how the lines fit together.
Hugh Adamson
www.hatchkit.com.au
autocadding
in reply to: hugha
Thanks! Just seeing this now.
Problem is - that even when I figure out how to make a pattern, the whole numerical sequence is so completely non-intuitive that I forget almost within a day how I've done it.
I thought SUPERHATCH was the solution when I first learned about it - but for example, when you use it to create a floor tile pattern in an area that requires 100 insertions - you get 100 overlapping boundary lines.
There should be some sort of AutoCAD system where you could just generate a hatch pattern sequence just by drawing lines within a programming window, for example.
A dialogue box would be really helpful for generating patterns since it could specify height, width, location of lines..
Thanks, though.
pendean
"...A dialogue box would be really helpful for generating patterns since it could specify height, width, location of lines.."
HATCH command's SETTINGS sub-option for predefined hatches, for custom hatches you probably need to purchase a third party tool like HATCHKIT among others http://www.hatchkit.com.au/faq.php
”Boost
