AutoCAD 2013/2014/2015
michaelmead
Message 1 of 43 (1,043 Views)
Accepted Solution
AutoCAD genius NEEDED
1043 Views, 42 Replies
09-26-2012 07:43 PM
Hi, I am a BIM Coordinator and work with Revit every day, but AutoCAD has me pulling out my hair and beating my head against my keyboard because it takes so long to do the most mundane tasks! I have a "super" computer with 32GB (yes 32GB) of RAM, a large SSHD, with twin xeon E5-2650 processors (so it’s NOT a hardware issue). But when I open a 10MB (yes only 10MB!) CAD file (.dwg) from one of my cross company co-workers and I simply try to rotate it in 3D view, or try to explode everything it seizes up (or just spins my little mouse curser for like 10 min! seriously) What gives!?!? I’ve had Autodesk support on the line many times and they are always like sign out of the on-line thing and turn on your hardware accelerator. Seriously?? That’s all you got? Like I didn’t think of that? Come on, I know there is an AutoCAD genius out there that knows WTF is up with this crap. I read somewhere that the command exporttoautocad and aectoacad commands dumps a lot of BS out of the files and that helped a little, but what I need is a major AUTOCAD enema! PLEASE PLEASE PLEASE HELP!! I beg you! P.S. AUTOCAD you suck!!
-Thanks
In some 3d models I have found that one particular 3d object can cripple a drawing. I'd suggest freezing portions of the file and trying to orbit after each layer freeze. Once the offending layer is found, isolate it and look for 3d objects that are just a bit too detailed for their own good. Think: Screws with threads, 3d logos on Vendor provided 3d models.... Another thing to consider is how far objects are from 0,0,0. If they are too far away Autocad just can't handle it.
*Expert Elite*
Patchy
Message 2 of 43 (1,034 Views)
*Expert Elite*
3wood
Message 3 of 43 (1,019 Views)
Re: AutoCAD genius NEEDED
09-26-2012 11:06 PM in reply to: michaelmead
Can you post the drawing in 2007 format please?
Member
tatakpinoy
Message 4 of 43 (1,011 Views)
09-27-2012 12:53 AM in reply to: michaelmead
Can you try this.. in the command prompt
1) purge
2)audit
3) _scalelistedit, enter delete
jfountain
Message 5 of 43 (980 Views)
09-27-2012 07:11 AM in reply to: michaelmead
I'm sure Autodesk asked, but do you have a supported video card with the latest drivers installed?
michaelmead
Message 6 of 43 (977 Views)
09-27-2012 07:13 AM in reply to: 3wood
I tried to attache the 2007 format...but I got the error message:
Please correct the highlighted errors and try again.
  • The attachment file size is too large. The maximum file size is: 1,572,864 bytes
michaelmead
Message 7 of 43 (976 Views)
09-27-2012 07:14 AM in reply to: jfountain
Yes, I do. I have a NVIDIA Quatro 4000
jfountain
Message 8 of 43 (964 Views)
09-27-2012 07:28 AM in reply to: michaelmead
I guess I have no other ideas then. I just exported a Revit model to AutoCAD. opened the 61 mb file in AutoCAD. It was slower than revit to revolve the model, but it wasn't terrible.... I'm not familiar with your processors, are they AMD or Intel? I thought I read somewhere that AutoCAD had issues with AMD processors. I could be wrong though.
New Member
RYANCLYFORD
Message 9 of 43 (958 Views)
09-27-2012 07:42 AM in reply to: michaelmead
Whenever I run into this problem from co-workers it is because they made a hatch detail at an infinately small scale which is holding about 1000000 lines in it. Even if you have an amazing computer autocad hatches had hold millions of lines in a single hatch, no matter the size.
I would suggest opening your drawing, typing in "hpmaxlines" into the command line, changing the default to 1000 saving the drawing, shut down autocad, restart it and open the drawing. You will have to fix your hatches to be scaled to new sizes and they may not look as good, but you should use as small of a "hpmaxlines" as possible to get through with descent looking drawings. Hope that works.
Distinguished Contributor
Hammer.john.j
Message 10 of 43 (954 Views)
09-27-2012 07:52 AM in reply to: michaelmead
10MB is very large for a cad file.  We have some 2 mile long road projects with surfaces approaching this file size and we've found that the profile view really causes hangups with performance... there maybe other things that degrade performance also.  What is the content of the drawing thats pushing you to 10mb would be my first question.
John Hammer, LA
Dell Precision T3500 - Xenon W3550 @ 3.07 (4 core)
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
NVIDIA Quadro 2000 - Dual Monitors
Cat 6 network with GlobalScape Avail Agent - WAFS
Infrastructure Design Suite Premium and Civil 3D 2012 & 2014
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
