AutoCAD 2013/2014/2015
1 Kudo
Post 1 of 6
Autocad from Product Design Suite, Factory Design Suite
277 Views, 5 Replies
01-13-2013 10:11 PM
Scenario: We have Product Design Suite and Factory Design Suite Standard, both are network license. Out of few application inside these suite, we only use AutoCAD for the moment. We had combined the license file.
Question: can we install all Product Design Suite (or either one) as client in computer, and start AutoCAD? The reason of this is because we are only using AutoCAD, we purchased different suite depend on the price quote from time to time.
Thanks.
Thanks, this information is very useful for me.
61 Kudos
Post 2 of 6
Re: Autocad from Product Design Suite, Factory Design Suite
01-14-2013 09:14 AM in reply to: skhuam
I am not sure about the question (what you use now and what you plan to use), but if the question is whether you can run AutoCAD from the Design Suite (either one) and consume a "Suite" network license for it, then yes - you can do this.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
1 Kudo
Post 3 of 6
01-14-2013 06:09 PM in reply to: vladimir.michl
Yes Vladimir Michl,
That is exactly what I mean. Thanks for your information.
135 Kudos
Post 4 of 6
01-15-2013 02:06 AM in reply to: skhuam
Does the following link explain things better for you? http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17532548&linkID=9240617
Duncan
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Duncan Brannan Send DuncanBrannan82 a Private Message
651 Kudos
Post 5 of 6
01-15-2013 06:46 AM in reply to: DuncanBrannan82
also this one for Product Design and Factory Design Suite: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17437350&linkID=9242018
1 Kudo
Post 6 of 6
01-15-2013 06:17 PM in reply to: skhuam
