AutoCAD 2013/2014/2015
Distinguished Mentor
darawork
Message 1 of 6 (168 Views)
AutoCad DWG - Archiving System...?
168 Views, 5 Replies
02-05-2013 06:08 AM
Hi all,
Our company has thousands of drawings. We need to be able to find drawings based on a number of factors, namely 'client name'.
Is there any way to embed this 'attribute' post-autocad to the DWG file, so as to be able to search folders (or the whole :drive)? Some external software solution would be ideal. Like adding ID3 tags to MP3s, although it would be 'client name' to DWGs.
Does anyone currently use some similar technique to embed this 'tag'..?
Something with a batch assign command would be ideal, as mentioned there are thousands of DWGs already. Adding an extra attribute to the titleblock would be a last resort, as you can imagine.. this would take ages.
System information: Win7 x64 / 3DSMax Design 2015 / AutoCad 2014 / Xeon E31225 quadcore @3.10Ghz / nVidia GTX760 2GB (344.11 Driver) / 24Gb Ram / Corsair 650w
pendean
Message 2 of 6 (165 Views)
Re: AutoCad DWG - Archiving System...?
02-05-2013 06:16 AM in reply to: darawork
While in AutoCAD, in a file, start DWGPROPS command and fill in the fields you need/want. That info shows up in Windows Explorer's PROPERTIES of each file, is searchable, and ADCENTER's search inside AutoCAd can also find them.
Or it's time for you all to explore better file management using a tool like AutoCAD VAULT.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
darawork
Message 3 of 6 (148 Views)
02-05-2013 09:11 AM in reply to: pendean
Thanks for the reply, I'll check into those now.
dgorsman
Message 4 of 6 (139 Views)
02-05-2013 10:37 AM in reply to: darawork
Seconded on Vault and other EDMS systems.  Chances are you are dealing with not only DWGs but PDFs, Excel workbooks, and a host of other files, and with that many file types and counts its easy to get beyond a point where a conventional Windows search is impractical.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
darawork
Message 5 of 6 (120 Views)
02-06-2013 03:25 AM in reply to: pendean
DWGPROPS -> Set Title [Variable]
ADCENTER -> Search [Variable]
In conjunction with custom PROPULATE Templates, this process could actually work quite nicely.
Now.... if only AutoDesk could fix their Shell intergration with Windows Explorer Columns, that would be handy.
The existance of a 3rd party hack, which costs money, is not ideal. Nor is purchasing VAULT as a solution for something that did work in previous versions, but now is broken. Also, VAULT is comparitive to fixing an ingrown toenail with a jack-hammer in this case. Thanks, but no.
darawork
Message 6 of 6 (117 Views)
02-06-2013 03:34 AM in reply to: darawork
On a separate note; is there anyway to invoke the 'Design Center' Search dialogue box via the command line? Or ideally, from outside AutoCad via the DOS command prompt or as a standalone executable?
