Hey all,
Just gonna start of by saying sorry for the lack of clarity in the subject of the post. Just couldn't come up with a way to explain the issue in a few words.
The problem I'm having is an odd one. I'll type a command into the command line (typically through a keyboard shortcut) and Autocad recognizes that it's the command I want, then in the series of clicks and inputs for the command it will seemingly cancel the command I was in the middle of and execute a different one at what seems like random. ex. I type in 'tr' for trim and then go to select the fence and trim and before I can the command turns into copy instead... or it will try and render something, so it will bring up a toolbar... All 3 of these events happened when I started with the trim command so it doesn't seem to be confusing 1 command with another it's just doing random junk. This happens when I do different commands and seems to come and go in spurts. Super annoying!
A little bit of background that might help. Yesterday I was having trouble with opening drawings. I would open the file, it would load up fine initially and then it would freeze before the drawing fully loaded. and in the process it would kick out a 'ACAD.lsp' file to my desktop that was filled with gibberish. If I hit esc immediately after opening it seemed to work fine, so I figured it was something in the startup suite, I cleared all the lisps I had loaded up and cleared all the startup settings I had created and that didn't work. So I ended up resetting autocad back to it's default settings and then loaded up my profile and .pgp file and everything seemed to be all good. Never figured out what caused that problem in the first place but figured whatever it was got cleared up with the settings reset. Don't know if these events are connected but it seems like they might be.
Any ideas?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
My search delay is set to 1500 and I don't have autocomplete enabled. I've encountered that problem before, this is different. It's not searching or trying to complete my input and getting a different command than intended. I'll actually be in the middle of a command when it happens. For instance, I will go to trim something, type in the command, pick the line I want to trim to and then as I'm going to select the lines I want to trim it's like autocad short circuits and is then in the middle of a different command. I don't know how else to explain it and I can't reproduce the situation on demand. Where the command short circuits and to what command is different everytime....
Ever find a solution to this? I have a coworker with the same issue, random commands being exicuted during another command. (autocad LT 2015)
The most recent they were erasing and somehow got into the laydel command.
That sounds like a virus, search the internet for "acad.lsp virus".
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
