Good afternoon guys,
I installed autocad 2014 on my windows 8 and it worked perfectly, but soon after installation did windows update to 8.1 and then immediately opened the autocad not more, telling me the following message:
honestly do not know what else to do since I installed autocad pack 1 already changed the rse.dll and nothing works, could someone help me?
thanks
Despite the numbering, changing from Win8 to Win8.1 isn't a simple patch or update but effectively a new operating system. Like any other operating system migration there are effects on software operation and licensing. When changing operating systems its best to do extensive research beforehand (such as whether current software is supported under the new version) and start from scratch. Its also makes for a good opportunity to clear out the deadwood of old programs and settings which accumulate over the years.
Hello
+1 with Dgorsman & Pendean
Upgrading from Win 8.0 to Win 8.1 with an ACAD 2014 already installed and running is the "worst" situation !
You have a "good" chance to install the 2014 (not supported at all by Autodesk) on a "fresh" Win 8.1 ...
Patrice BRAUD
AutoCAD 2014 appears to be supported on Windows 8.1
For 64-bit AutoCAD 2014
Hello from France
In theory, ACAD 2014 is supported with Windows 8.1 !
But before 15 April 2015, it was not ... as far as I know ...
... Autodesk has moved a little bit !
I know people who could not install ACAD 2014 on Win 8.1 and some others "no problem" !?
Patrice BRAUD
Hello
+1 with Pendean & Dgorsman !
As I said >>> Upgrading from Win 8.0 to Win 8.1 with an ACAD 2014 already installed and running is the "worst" situation ! <<<
Patrice BRAUD
