"Buffer" may have different meanings to different people - it has specific technical connotations which may not match what you are stating. A better description may be necessary to get a good solution.
@feldaleeargel4527 wrote:
For Clarity, BUFFERS OR BUFFERING in this case means that the AutoCAD freezes with the buffering/freezing wheel (wheel timer- I am not sure what it is called) in the middle of the screen. While this is happening, obviously there's nothing I can do but wait till the screen is active again.
Post a DWG that demonstrates this behavior.
Here are pictures of the problem, I even video recorded it but is unable to attached here... Hoping this is enough explanation of the problem and hear possible cause and solutions...Thanks.
@feldaleeargel4527 wrote:Here are pictures of the problem, I even video recorded it but is unable to attached here... Hoping this is enough explanation of the problem and hear possible cause and solutions...Thanks.
Posting blurry pictures of a spinning blue wheel does nothing to help figure out what is going on. Try sending a picture of your car not running right to a mechanic and see how far you get.
Post a DWG in which this behavior occurs.
Is that AutoCAD or one of the verticals like Civil3D?
Did you fix the buffering problem? Recently having this problem with AutoCAD 2014 LT.
