hi,
please give me reason and solution for that
"when i give command MAPIINSERT then my autocad becomes hang for a long time"
regards;
vijay sharma
First this is the AutoCAd 2013,2014,2015 forums for questions on those versions not 2006 versions.
Second Mapiinsert is a AutoCAD Map3D command not a vanilla (plain) AutoCAD command.
So first are you using AutoCAD MAP3D, and if so you may want to ask in its forum .
Also what are the specs to your workstation and the paths to the images?
