Geolocation is not displaying after turning it on. I have tried the following:
1) Opening a .dwg that had displayed properly yesterday.
2) Remaking the geolocation marker.
3) Checked latest updates.
4) Starting a completely new .dwg and setting a new geolocation.
5) Typing "Regen"
6) Switching to a different Visual Style (i.e. 2D Wireframe, Hidden, etc.)
7) Restarting computer.
I may have tried other trouble-shooting meathods, but cannot seem to get the geolocation underlay to show up again. See attached image for what I'm looking at currently. Thanks.
Solved by DarrenP. Go to Solution.
I am experiencing the same problem with this tool in Autocad LT 2014, the company where I work. Just confirming this would be a technical problem in the existing tool, and are working to resolve?
I would like to be informed, so that the solution is found, depending on much of this wonderful tool, including the principal reason for purchasing the software for the company where I work.
I await news.
Thanks for listening,
Mario Luiz Vieira-Brazil
We are using the 30 day trial of ACAD.
The first few days Geolocation worked great. Then it quite (similar to other posts - map does not appear in Model Space) and hasn't worked since.
This function is extremely useful in our firm and a prime reason we are consider purchasing the software.
Please post the latest progress on a solution.
- Steve,
Innovative Engineering, Inc.
from autodesk:
AutoCAD 2014 and 2015 products are experiencing a Bing Maps outage due to a Microsoft security change. The AutoCAD team is working to address this as quickly as possible. Please see the following support article for updates, which will also be visible in product (once available) while using the GeoLocation commands.
DarrenP
Hello Darren,
When you say; "which will also be visible in product ", do you mean this fix will come to us as part of an automatic software update or a Service Pack update or something else? (fyi - I'm new to how ACAD is updated when something like this is corrected)
- Steve
The fix was not automatic for me. It took using the old noggin a little to install it. But everything works fine now.
Thanks!
The "Readme" file was a good guide, here it is:
