AutoCAD Forum
AutoCAD 2105: Re-ordering layouts has an issue,
4 REPLIES 4
JamaL9722060
581 Views, 4 Replies
For example, in the attached screenshots, I wanted to move “layout1” to be at the end of all layouts (as marked in red in the second screenshot). It appears that this cannot be done in one go.
Is there a way to perform this in one go?
Thank you
Best
Jamal
Jamal Numan
4 REPLIES 4
nestly2
in reply to: JamaL9722060
I dislike the new Layout tab behavior.
Using the legacy method, right click on the layout you want to move and pick "Move or Copy" from the menu.  Pick a new location in the list and click "OK"
JamaL9722060
in reply to: nestly2
Very much appreciated nestly2
Does this mean that drag dragging the layout and dropping it the location we want is not valid any longer?
Jamal Numan
nestly2
No, you can still drag the layouts to re-order them, but as you've discovered, if the list is truncated, you can only drag them to the end of what's visible.
JamaL9722060
Many thanks
Sure, I meant to be able to drag and drop beyond the layouts that are visible
Best
Jamal
Jamal Numan
”Boost
