AutoCAD 2105: Re-ordering layouts has an issue,
For example, in the attached screenshots, I wanted to move “layout1” to be at the end of all layouts (as marked in red in the second screenshot). It appears that this cannot be done in one go.
Is there a way to perform this in one go?
Thank you
Best
Jamal
Solved by nestly2. Go to Solution.
I dislike the new Layout tab behavior.
Using the legacy method, right click on the layout you want to move and pick "Move or Copy" from the menu. Pick a new location in the list and click "OK"
Very much appreciated nestly2
Does this mean that drag dragging the layout and dropping it the location we want is not valid any longer?
No, you can still drag the layouts to re-order them, but as you've discovered, if the list is truncated, you can only drag them to the end of what's visible.
Many thanks
Sure, I meant to be able to drag and drop beyond the layouts that are visible
Best
Jamal
