hi what do you mean? can post some screen shot?
Hello
Welcome to the Autodesk/AutoCAD Forums !
I am using often ACAD 201X on a 27" screen (Resolution: 2560x1440) ...
So I can admit that a laptop with 3200x1800 screen, could be "difficult to use/see" for ACAD and some others programs ...
And with the display on an external screen 24/27", is it ok ?
Today some people are buying Laptops without a too high resolution for this reason !
Patrice BRAUD
moe1995,
You can easily adjust the resolution of your laptop.
Click on the Windows Start button and type into the search box "resolution" Several options will be found. Of course you must realize that all of your programs will take on a larger appearance. Another option may be to adjust the text size and other object sizes such as Title bars, Scroll bars, Button sizes, etc.
Or reading glasses may help.
Hello
YES but resizing your Windows Interface to 125% or 150% because you have a very high resolution is not ALWAYS a s good solution ...
People with a 4K display complain more about this problem !!
For example :
http://www.cad-notes.com/autocad-text-overlapped-in-some-palettes
http://forums.autodesk.com/t5/autocad-2013-2014-2015/4k-monitor-display-issues/td-p/5081746
So Good Luck and thks for your feedbacks ...
Patrice BRAUD
Hi:
Our company recently upgraded to R2015. I finally have my machine the way that I want it except for the Layers toolbar.
In 2013 the Layers tool bar had 3 different pulldowns on it. The Layer pulldown, the linetype pulldown and the lineweight pulldown, allowing you to use the "by layer" function in each one of the layer and linetype pulldowns.
How do I these back to this toolbar, or add that functionality back on the layer 1 toolbar. I'm quite familiary with customization, and have not been able to find those 2 drop down menus in the command CUI interface.
Can you help please??
I'm working on old client drawings that would be vastly improved by having these 2 features available.
Adriana West (cadmentr)
Hello Adriana
Please could you create a NEW Topic/Thread for your problem/question !
THIS thread is speaking about "very high" resolution and ACAD 201X ...
Thks in advance !
Patrice BRAUD
