You used to be able to type in whatever scale you wanted in the Viewports toolbar. Looks like they have done away with this option. Does anyone know where I can type in custom sizes now? Where did this ability move to or how do I get it back?
Thank!
i can find the the view tap in my autocad 2015, how should i give the view port scale.
welcome @forums.autodesk.com!
Look to my screenshot, you can change by selecting the viewport and then use the property-window or the scalelist-item in the lower statusbar.
HTH, - alfred -
the options that you are showing as image does not work on Autocad 2015 Education version.
when I try Custom Scale or edit scale list the program stops working.
we ARE actually going backwards!
Autocad used to be that simple program everybody could start and draw lines in it and couple excellent useful command to use for manipulating the work. now its a program like revit or any other program hard to underestand too many bottuns hard to way finding. I think it has lost its main primary goal!
Not happy not happy !!
