Is there a limit of objects that this command will create? Having issues with the command not working after a certain amount objects. Also, after creating an object with view base, it has a tendency to create red frames around the objects that I have created, of which edit view will not work on parent object. Can't update objects at all.
I’m not reaching a limit yet on the objects
If my reply post was helpful, please give a "Kudos" or mark the "Accept as Solution" button below (or both).
That drawing may have got corrupted somehow(?)
