I have an odd problem. Sometimes when I have multiple drawings open my commands are entered on a different drawing than the one that is "active". For example, I have two or three drawings open. I switch to one and type a command. Nothing appears on the command line. However, when I click on another open drawing, the command might be there! If I click back to the original drawing Autocad usually catches up and enters commands correctly.
I had the same problem on my old computer after switching to Acad 2015. I figured it was becase the hard drive was very full and consequently much slower, but the brand-new computer (also Win 7) does the same thing.
Any ideas?
Solved by pendean. Go to Solution.
I use the built-in tabs from Autocd 2015. I suppose I could switch back to ctrl-tab to switch, but that seems to be a step back.
Have you ever seen this happen in the middle of a command? i have staff that are having similar issues. But what is happening to them is they will have multiple tabs open and when auto-save kicks in (as the command is kicked off) the resulting command switched to another tab.
Example... Doing a zoom extents from the KB (old school) and type Z enter E enter, but the Auto-save got kicked off from the zoom command. now for some reason you don’t see the "E" in your command line. The "E" is in the command line of one of the other tabs that was never opened.
When i first heard them complaining about it i thought it had to be operator error, but i have seen it happen on multiple PC's to multiple staff.
Any ideas..... ?
Howard Munsell
Interesting, i had one of my guys demonstrate it for me about an hour ago. He had a fresh session of C3D open and 2 files that had only open for a min or two. i set the autosave to 1min for convince and he started working. within the first autosave it was doing it. he typed Z for zoom, autosave kidked in and no E..... the E was on the command line of the other drawing tab that had not been activated. Weird.....
Howard Munsell
i couldn't duplicate it on My PC either.... 🙂
I have a handful of staff that it does happening to though and it only seems to happen in C3D 2015.
Howard Munsell
This problem still exists, and it is impacting my productivity. This is on Civil 3D 2019.1.2. I don't think it was this frequent on version 2018.
It's very frustrating to have to stop what I am doing, close all drawings, and start again. This can happen as often as every few minutes under the worst circumstances.
Disabling autosave and saving less often doesn't seem like a good solution. Autodesk has trained us to save constantly because of all the other unfixed bugs and crashes. Plus user error, which can happen to any of us. "What did I just do? Hmm, last save was 2 minutes ago. I will just close and reopen."
It would be nice to see this fixed. I don't know if the Command Line is a high priority for Autodesk, as it's not new and shiny.
This bug intersected with another 2019 bug yesterday. The "Level of Detail" toggle is missing from the 2019 Ribbon. Autodesk just said "oops", you have to type the command to run it. But the command line had stopped working, so I couldn't type. 😕
I think you are experiencing a different problem. You should probably post over in the C3D forum as this is not a common issue in plain old AutoCAD as you can see by this thread.
The commandline works all the time so far the program works and no dialog window is open.
There is no need to close everything and restart Civil 3D. Just run the command LEVELOFDETAILOFF, and never turn that on again.
I don't think you read my post. I couldn't type any Level of Detail command because the command line didn't work ... as mentioned by the original poster. Two issues intersecting.
My installation experiences the command line problem as described by the original poster. I found this page by searching for a solution to the problem I was facing. As this thread shows, it affects multiple versions of the software, both with and without verticals like Civil 3D.
