After a while the user is working (not no start) AutoCAD show whis message (in italian).
Wat is the problem ?
The customer has MANY more installation then licenses.
Solved by pendean. Go to Solution.
No Pendean,
The error you refear will appear when you try to obtan a license (on start of AutoCAD).
My error appear "looks randomly" after some hour of work.
And my error is an "AutoCAD Message" not a "Licensing Error" ... looking at the progran bar at the top.
Thats can be ! They use to manage HUGE dwg file.
But is it a software limitation or with better hardware this limit can be pushed to more big file size ?
