AutoCAD Forum
AutoCAD 2015: New System Variables
6 REPLIES 6
nrz13
2506 Views, 6 Replies
The system variable for the new Create/Learn tab that loads at startup is NEWTABMODE (0 = off; 1 = on)
The system variable for the new highlight visual representation is HIGHLIGHT (0 = off; 1 = on)
Others can add other new variables below as they come across them.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
6 REPLIES 6
pendean
in reply to: nrz13
Highlight is the same as older versions: was there a functionality you meant to identify as well?
Tap HELP in 2015, on the homepage under Resources is a list of New, Updated and Obsolete commands and system variables in 2015.
Look up the new LINESMOOTHING, new in 2015: nice visual 'fix' added, I like it.
nrz13
in reply to: pendean
Ha ha, I didn't notice the "New Commands and System Variables" even though it was right below the "System Variables" link I clicked on.  Sorry, I don't normally use the built-in help.  Usually I just do a Google search for what I want, but since no one has released documentation for it yet, I couldn't do it that way this time.
When was the HIGHLIGHT command introduced?  I had never seen that before.  It must have been off by default for my previous installs???
pendean
in reply to: nrz13
HIGHLIGHT has been around forever.
nrz13
Is it just that it looks different in 2015?  I don't have a previous install anymore to compare it to.  When I turn Highlight off it looks odd to me, but I can't figure out why exactly.  It definitely never used to add a blue border to everything for me.
Edit:  It used to dash selected items in
pendean
in reply to: nrz13
That 'blue edging' to objects is new to 2015: in 2014 and older, ther was no blue 'edge' to everything, it just 'ghosted' in appearance.
cad-pe
in reply to: nrz13
Yes, HIGHLIGHT has been around since atleast Release 9 or before.
However, the programmers at Autodesk were showing off their programming skills for the "blue-ish" highlight. To turn-off the "blue-ish" highlight, use SELECTIONEFFECT = 0.
The programmers at Autodesk at time seem to have no sense of the notion of "keep it simple" to aid in production speed.
”Boost
