AutoCAD Forum
AutoCAD 2015 map update
3 REPLIES 3
winner117
864 Views, 3 Replies
We insert a location map into our drawing.
It looks like the Ariel map is not up to date.
Is there anyway to update the maps?
3 REPLIES 3
vladimir_michl
in reply to: winner117
If you have inserted a clipped map, you can update it through a right-click (Map > Update) or through the contextual ribbon (Update, or the GEOMAPIMAGEUPDATE command). You can expect updated content only if Bing has updated its maps in the meantime.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
winner117
in reply to: vladimir_michl
Somehow the map data is not up to date.
I just put the map on to my drawing, but I check the same location on google map, it's out dated.
vladimir_michl
The reason is probably in different map sources, Microsoft Bing Maps used in AutoCAD are based on different map sources (maybe older, maybe newer) than Google Maps. You can also try PlexEarth Tools for accessing Google Earth mapsů
”Boost
