I just got the 2015 version yesterday and am noticing some simple things from previous versions that have changed, and I can't seem to figure out... One that is killing me is trying to place a line from a point/grip at a specific extension distance. It shows the "x" as I follow along the existing line, but as soon as I type in a specific distance I want it to begin at, it throws my line starting point seeminling random into model space...Can anyone explain why it is this is happening...and hopefully there is a simple way to fix it??? Thanks!
Believe it or not, the start point isn't "random" but neither is it the correct behavior. I'll explain it if you want, but the short answer is that there's a bug in AutoCAD when both Dynamic Pointer Input is disabled and the Command Line is floating.
If you dock the Command Line, OR turn on Dynamic Pointer Input, it should work as you expect.
Right click on the Dynamic Input Icon and/or use DSETTINGS to access the Drafting Settings > Dynamic Input tab. You can experiment with which works best for you, but I don't recommend using the "Dimension Input" if you frequently use tracking.
Sorry I mis-diagnosed your problem, but I still have more ideas.
Is this a clean install of AutoCAD2015, or did you migrate your setting from a previous version?
If a clean install, are you basically running the default settings, or did you go into "Options" and "DSETTINGS" and change setting to suit your preferences?
I'm just trying to get a feel for how close AutoCAD is to it's "default settings"
Also, what's the previous version you referenced? Things change a little evey year, so knowing which release you're comparing 2015 to might be helpful
Last request is a screenshot that shows your status bar, and what it looks like just before you press <enter> and the line snaps to a "random" point (siimilar to what's shown below)
