Autocad 2015 lagging commands, move and copy, delays work.
can someone help me, i installed autocad 2015 last week , now i cant even move and copy a drawing or an object , it takes more than 5 minutes to move and copy , please help
Solved by nrz13. Go to Solution.
So you could work the last week without issues?
My question is now: what happend to the drawing or to your system within the last day's. Any Windows updates, graphic driver updates, or any new applications installed?
An important question is also if that happens only in an existing drawing or it does also show that lag's in new drawings with just one line.
- alfred -
Hi, it is the same for me but only if my selection includes CONSTRAINS, it takes forever for autocad to operate.
At the beginning I thought it was only from older drawings but not. Autocad is freezing on any command done on anything that is constrained.
It does not occur every single time but once it started to freeze on these, nothing to do for it to stop freezing unless to un-constrained the objects.
If you haven't already, install SP1 and maybe SP2. They fix some performance issues.
Hi thanks for your reply i am using NVIADIA geforce GT 640M 2 GB ,update to the Latest Driver Version: 344.75
Hi how do i ignore the constraints, or how do i resolved them, if its the cause of the lagging
How to turn off and delete constraints in AutoCAD
Well if you don't use them and don't have them applied you don't need to turn them off or delete them.
If you think that there is constrains applied and you don't know much about them, you can show the toolbar "Geometric onstrains" and find the "delete constrains" icon. Select everything and "delete constrains"... and you'll see.
So it works for you?
For me, this is a major bug that have to be fixed. I worked with these all the times ans I can't do it anymore because ACAD freezes...
BS
Hope that it will be fixed with patched and I don't know how effectively tell the problem to autodesk...
Troispistols:
If you are on subscription service, login to the Autodesk Subscription Center and start a new ticket.
Otherwise, report the bug here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Ok thanks you for the info, i'm on subscription, i'll check this out. Thanks
