AutoCAD Forum
Autocad 2015 lagging commands, move and copy, delays work.
12 REPLIES 12
Message 1 of 13
mumukshu86
8014 Views, 12 Replies
can someone help me, i installed autocad 2015 last week , now i cant even move and copy a drawing or an object , it takes more than 5 minutes to move and copy , please help
12 REPLIES 12
Message 2 of 13
mumukshu86
in reply to: mumukshu86
 I am not even able to edit my blocks , please help
Message 3 of 13
So you could work the last week without issues?
My question is now: what happend to the drawing or to your system within the last day's. Any Windows updates, graphic driver updates, or any new applications installed?
An important question is also if that happens only in an existing drawing or it does also show that lag's in new drawings with just one line.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 13
Troispistols
Hi, it is the same for me but only if my selection includes CONSTRAINS, it takes forever for autocad to operate.
At the beginning I thought it was only from older drawings but not. Autocad is freezing on any command done on anything that is constrained.
It does not occur every single time but once it started to freeze on these, nothing to do for it to stop freezing unless to un-constrained the objects.
Message 5 of 13
nrz13
If you haven't already, install SP1 and maybe SP2.  They fix some performance issues.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 6 of 13
Hi thanks for your reply i am using NVIADIA geforce GT 640M 2 GB ,update to the Latest Driver Version: 344.75
Message 7 of 13
mumukshu86
Hi how do i ignore the constraints, or how do i resolved them, if its the cause of the lagging
Message 8 of 13
nrz13
How to turn off and delete constraints in AutoCAD
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Message 9 of 13
Troispistols
Well if you don't use them and don't have them applied you don't need to turn them off or delete them.
If you think that there is constrains applied and you don't know much about them, you can show the toolbar "Geometric onstrains" and find the "delete constrains" icon. Select everything and "delete constrains"... and you'll see.
Message 10 of 13
mumukshu86
in reply to: Troispistols
 thank you 🙂
Message 11 of 13
Troispistols
So it works for you?
For me, this is a major bug that have to be fixed. I worked with these all the times ans I can't do it anymore because ACAD freezes...
BS
Hope that it will be fixed with patched and I don't know how effectively tell the problem to autodesk...
Message 12 of 13
nrz13
Troispistols:
If you are on subscription service, login to the Autodesk Subscription Center and start a new ticket.
Otherwise, report the bug here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Message 13 of 13
Troispistols
in reply to: nrz13
Ok thanks you for the info, i'm on subscription, i'll check this out. Thanks
”Boost
