So our office is in the process of upgrading everything to the new 2015 due to our subscription that i must say we are getting ripped off.
We pay thousands of dollars every year for new autocad / revit suite and for what? NOthing but garbage.
The new autocad doesnt work for crap. half the commands arent recognized, its slower than crap and i must say i feel ripped off.
Its slow, sluggish, ddedit doesn't even work to edit text. Unbelievable. Anyone have any ideas of where to start.
I have go things working better by turning most every feature off but its still very slow.
This is what i get for when i type DD for the ddedit.
Select object: Unknown command "DDEDIT". Press F1 for help.
<Entity name: FF72CCC0>
then you type out ddedit and it works but it takes forever to thing about it. Unreal! to say the least. Autodesk is turning into complete garbage
Oh and most the commands you have to type in at least twice in a row for it to start recognizing them.
This isnt only on one machine either, its on several
It sounds like your PGP file needs updated. "DD" has NEVER been the command for editing text -- your PGP file contained a line that said DD started the DDEDIT command and it sounds like the new install doesn't have that anymore. And if that's the case, I'm betting the same holds true for the other commands that "aren't recognized".
EDIT: Just in case you don't know what a PGP file is, here's what mine looks like (from 2012). And if you want to find where YOURS is, type the following in acad at the command line -- be sure to include the parenthesis. (findfile "acad.pgp")
; ; ; Program Parameters File For AutoCAD 2012 ; External Command and Command Alias Definitions ; Copyright (C) 1997-2011 by Autodesk, Inc. All Rights Reserved. ; Each time you open a new or existing drawing, AutoCAD searches ; the support path and reads the first acad.pgp file that it finds. ; -- External Commands -- ; While AutoCAD is running, you can invoke other programs or utilities ; such Windows system commands, utilities, and applications. ; You define external commands by specifying a command name to be used ; from the AutoCAD command prompt and an executable command string ; that is passed to the operating system. ; -- Command Aliases -- ; The Command Aliases section of this file provides default settings for ; AutoCAD command shortcuts. Note: It is not recommended that you directly ; modify this section of the PGP file., as any changes you make to this section of the ; file will not migrate successfully if you upgrade your AutoCAD to a ; newer version. Instead, make changes to the new ; User Defined Command Aliases ; section towards the end of this file. ; -- User Defined Command Aliases -- ; You can abbreviate frequently used AutoCAD commands by defining ; aliases for them in the User Defined Command Aliases section of acad.pgp. ; You can create a command alias for any AutoCAD command, ; device driver command, or external command. ; Recommendation: back up this file before editing it. To ensure that ; any changes you make to PGP settings can successfully be migrated ; when you upgrade to the next version of AutoCAD, it is suggested that ; you make any changes to the default settings in the User Defined Command ; Aliases section at the end of this file. ; External command format: ; <Command name>,[<Shell request>],<Bit flag>,[*]<Prompt>, ; The bits of the bit flag have the following meanings: ; Bit 1: if set, don't wait for the application to finish ; Bit 2: if set, run the application minimized ; Bit 4: if set, run the application "hidden" ; Bit 8: if set, put the argument string in quotes ; ; Fill the "bit flag" field with the sum of the desired bits. ; Bits 2 and 4 are mutually exclusive; if both are specified, only ; the 2 bit is used. The most useful values are likely to be 0 ; (start the application and wait for it to finish), 1 (start the ; application and don't wait), 3 (minimize and don't wait), and 5 ; (hide and don't wait). Values of 2 and 4 should normally be avoided, ; as they make AutoCAD unavailable until the application has completed. ; ; Bit 8 allows commands like DEL to work properly with filenames that ; have spaces such as "long filename.dwg". Note that this will interfere ; with passing space delimited lists of file names to these same commands. ; If you prefer multiplefile support to using long file names, turn off ; the "8" bit in those commands. ; Examples of external commands for command windows DEL, DEL, 8,File to delete: , DIR, DIR, 8,File specification: , SH, , 1,*OS Command: , SHELL, , 1,*OS Command: , START, START, 1,*Application to start: , TYPE, TYPE, 8,File to list: , ; Examples of external commands for Windows ; See also the (STARTAPP) AutoLISP function for an alternative method. EXPLORER, START EXPLORER, 1,, NOTEPAD, START NOTEPAD, 1,*File to edit: , PBRUSH, START PBRUSH, 1,, ; Command alias format: ; <Alias>,*<Full command name> ; The following are guidelines for creating new command aliases. ; 1. An alias should reduce a command by at least two characters. ; Commands with a control key equivalent, status bar button, ; or function key do not require a command alias. ; Examples: Control N, O, P, and S for New, Open, Print, Save. ; 2. Try the first character of the command, then try the first two, ; then the first three. ; 3. Once an alias is defined, add suffixes for related aliases: ; Examples: R for Redraw, RA for Redrawall, L for Line, LT for ; Linetype. ; 4. Use a hyphen to differentiate between command line and dialog ; box commands. ; Example: B for Block, -B for -Block. ; ; Exceptions to the rules include AA for Area, T for Mtext, X for Explode. ; -- Sample aliases for AutoCAD commands -- ; These examples include most frequently used commands. NOTE: It is recommended ; that you not make any changes to this section of the PGP file to ensure the ; proper migration of your customizations when you upgrade to the next version of ; AutoCAD. The aliases listed in this section are repeated in the User Custom ; Settings section at the end of this file, which can safely be edited while ; ensuring your changes will successfully migrate. 3A, *3DARRAY 3DMIRROR, *MIRROR3D 3DNavigate,*3DWALK 3DO, *3DORBIT 3DP, *3DPRINT 3DPLOT, *3DPRINT 3DW, *3DWALK 3F, *3DFACE 3M, *3DMOVE 3P, *3DPOLY 3R, *3DROTATE 3S, *3DSCALE A, *ARC AC, *BACTION ADC, *ADCENTER AECTOACAD, *-ExportToAutoCAD AA, *AREA AL, *ALIGN 3AL, *3DALIGN AP, *APPLOAD APLAY, *ALLPLAY AR, *ARRAY -AR, *-ARRAY ARR, *ACTRECORD ARM, *ACTUSERMESSAGE -ARM, *-ACTUSERMESSAGE ARU, *ACTUSERINPUT ARS, *ACTSTOP -ARS, *-ACTSTOP ATI, *ATTIPEDIT ATT, *ATTDEF -ATT, *-ATTDEF ATE, *ATTEDIT -ATE, *-ATTEDIT ATTE, *-ATTEDIT B, *BLOCK -B, *-BLOCK BC, *BCLOSE BE, *BEDIT BH, *HATCH BLENDSRF, *SURFBLEND BO, *BOUNDARY -BO, *-BOUNDARY BR, *BREAK BS, *BSAVE BVS, *BVSTATE C, *CIRCLE CAM, *CAMERA CBAR, *CONSTRAINTBAR CH, *PROPERTIES -CH, *CHANGE CHA, *CHAMFER CHK, *CHECKSTANDARDS CLI, *COMMANDLINE COL, *COLOR COLOUR, *COLOR CO, *COPY CONVTOMESH, *MESHSMOOTH CP, *COPY CPARAM, *BCPARAMETER CREASE, *MESHCREASE CREATESOLID, *SURFSCULPT CSETTINGS, *CONSTRAINTSETTINGS CT, *CTABLESTYLE CUBE, *NAVVCUBE CURVATUREANALYSIS, *ANALYSISCURVATURE CYL, *CYLINDER D, *DIMSTYLE DAL, *DIMALIGNED DAN, *DIMANGULAR DAR, *DIMARC JOG, *DIMJOGGED DBA, *DIMBASELINE DBC, *DBCONNECT DC, *ADCENTER DCE, *DIMCENTER DCENTER, *ADCENTER DCO, *DIMCONTINUE DCON, *DIMCONSTRAINT DDA, *DIMDISASSOCIATE DDI, *DIMDIAMETER DED, *DIMEDIT DELCON, *DELCONSTRAINT DI, *DIST DIV, *DIVIDE DJL, *DIMJOGLINE DJO, *DIMJOGGED DL, *DATALINK DLI, *DIMLINEAR DLU, *DATALINKUPDATE DO, *DONUT DOR, *DIMORDINATE DOV, *DIMOVERRIDE DR, *DRAWORDER DRA, *DIMRADIUS DRAFTANGLEANALYSIS, *ANALYSISDRAFTANGLE DRE, *DIMREASSOCIATE DRM, *DRAWINGRECOVERY DS, *DSETTINGS DST, *DIMSTYLE DT, *TEXT DV, *DVIEW DX, *DATAEXTRACTION E, *ERASE ED, *DDEDIT EL, *ELLIPSE ER, *EXTERNALREFERENCES ESHOT, *EDITSHOT EX, *EXTEND EXIT, *QUIT EXP, *EXPORT EXT, *EXTRUDE EXTENDSRF, *SURFEXTEND F, *FILLET FI, *FILTER FILLETSRF, *SURFFILLET FREEPOINT, *POINTLIGHT FSHOT, *FLATSHOT G, *GROUP -G, *-GROUP GCON, *GEOMCONSTRAINT GD, *GRADIENT GENERATESECTION, *SECTIONPLANETOBLOCK GEO, *GEOGRAPHICLOCATION GR, *DDGRIPS H, *HATCH -H, *-HATCH HE, *HATCHEDIT HB, *HATCHTOBACK HI, *HIDE I, *INSERT -I, *-INSERT IAD, *IMAGEADJUST IAT, *IMAGEATTACH ICL, *IMAGECLIP IM, *IMAGE -IM, *-IMAGE IMP, *IMPORT IN, *INTERSECT INSERTCONTROLPOINT, *CVADD INF, *INTERFERE IO, *INSERTOBJ ISOLATE, *ISOLATEOBJECTS QVD, *QVDRAWING QVDC, *QVDRAWINGCLOSE QVL, *QVLAYOUT QVLC, *QVLAYOUTCLOSE J, *JOIN JOGSECTION, *SECTIONPLANEJOG L, *LINE LA, *LAYER -LA, *-LAYER LAS, *LAYERSTATE LE, *QLEADER LEN, *LENGTHEN LESS, *MESHSMOOTHLESS LI, *LIST LINEWEIGHT, *LWEIGHT LMAN, *LAYERSTATE LO, *-LAYOUT LS, *LIST LT, *LINETYPE -LT, *-LINETYPE LTYPE, *LINETYPE -LTYPE, *-LINETYPE LTS, *LTSCALE LW, *LWEIGHT M, *MOVE MA, *MATCHPROP MAT, *MATBROWSEROPEN ME, *MEASURE MEA, *MEASUREGEOM MI, *MIRROR ML, *MLINE MLA, *MLEADERALIGN MLC, *MLEADERCOLLECT MLD, *MLEADER MLE, *MLEADEREDIT MLS, *MLEADERSTYLE MO, *PROPERTIES MORE, *MESHSMOOTHMORE MOTION, *NAVSMOTION MOTIONCLS, *NAVSMOTIONCLOSE MS, *MSPACE MSM, *MARKUP MT, *MTEXT MV, *MVIEW NETWORKSRF,*SURFNETWORK NORTH, *GEOGRAPHICLOCATION NORTHDIR, *GEOGRAPHICLOCATION NSHOT, *NEWSHOT NVIEW, *NEWVIEW O, *OFFSET OFFSETSRF, *SURFOFFSET OP, *OPTIONS ORBIT, *3DORBIT OS, *OSNAP -OS, *-OSNAP P, *PAN -P, *-PAN PA, *PASTESPEC RAPIDPROTOTYPE, *3DPRINT PAR, *PARAMETERS -PAR, *-PARAMETERS PARAM, *BPARAMETER PARTIALOPEN, *-PARTIALOPEN PATCH, *SURFPATCH PC, *POINTCLOUD PCATTACH, *POINTCLOUDATTACH PCINDEX, *POINTCLOUDINDEX PE, *PEDIT PL, *PLINE PO, *POINT POFF, *HIDEPALETTES POINTON, *CVSHOW POINTOFF, *CVHIDE POL, *POLYGON PON, *SHOWPALETTES PR, *PROPERTIES PRCLOSE, *PROPERTIESCLOSE PROPS, *PROPERTIES PRE, *PREVIEW PRINT, *PLOT PS, *PSPACE PSOLID, *POLYSOLID PTW, *PUBLISHTOWEB PU, *PURGE -PU, *-PURGE PYR, *PYRAMID QC, *QUICKCALC QCUI, *QUICKCUI QP, *QUICKPROPERTIES R, *REDRAW RA, *REDRAWALL RC, *RENDERCROP RE, *REGEN REA, *REGENALL REBUILD, *CVREBUILD REC, *RECTANG REFINE, *MESHREFINE REG, *REGION REMOVECONTROLPOINT, *CVREMOVE REN, *RENAME -REN, *-RENAME REV, *REVOLVE RO, *ROTATE RP, *RENDERPRESETS RPR, *RPREF RR, *RENDER RW, *RENDERWIN S, *STRETCH SC, *SCALE SCR, *SCRIPT SE, *DSETTINGS SEC, *SECTION SET, *SETVAR SHA, *SHADEMODE SL, *SLICE SMOOTH, *MESHSMOOTH SN, *SNAP SO, *SOLID SP, *SPELL SPL, *SPLINE SPLANE, *SECTIONPLANE SPLAY, *SEQUENCEPLAY SPLIT, *MESHSPLIT SPE, *SPLINEDIT SSM, *SHEETSET ST, *STYLE STA, *STANDARDS SU, *SUBTRACT T, *MTEXT -T, *-MTEXT TA, *TABLET TB, *TABLE TEDIT, *TEXTEDIT TH, *THICKNESS TI, *TILEMODE TO, *TOOLBAR TOL, *TOLERANCE TOR, *TORUS TP, *TOOLPALETTES TR, *TRIM TS, *TABLESTYLE UC, *UCSMAN UN, *UNITS -UN, *-UNITS UNCREASE, *MESHUNCREASE UNHIDE, *UNISOLATEOBJECTS UNI, *UNION UNISOLATE, *UNISOLATEOBJECTS V, *VIEW VGO, *VIEWGO VPLAY, *VIEWPLAY -V, *-VIEW VP, *DDVPOINT -VP, *VPOINT VS, *VSCURRENT VSM, *VISUALSTYLES -VSM, *-VISUALSTYLES W, *WBLOCK -W, *-WBLOCK WE, *WEDGE WHEEL, *NAVSWHEEL X, *EXPLODE XA, *XATTACH XB, *XBIND -XB, *-XBIND XC, *XCLIP XL, *XLINE XR, *XREF -XR, *-XREF Z, *ZOOM ZEBRA, *ANALYSISZEBRA ; The following are alternative aliases and aliases as supplied ; in AutoCAD Release 13. AV, *DSVIEWER CP, *COPY DIMALI, *DIMALIGNED DIMANG, *DIMANGULAR DIMBASE, *DIMBASELINE DIMCONT, *DIMCONTINUE DIMDIA, *DIMDIAMETER DIMED, *DIMEDIT DIMTED, *DIMTEDIT DIMLIN, *DIMLINEAR DIMORD, *DIMORDINATE DIMRAD, *DIMRADIUS DIMSTY, *DIMSTYLE DIMOVER, *DIMOVERRIDE LEAD, *LEADER TM, *TILEMODE ; Aliases for Hyperlink/URL Release 14 compatibility SAVEURL, *SAVE OPENURL, *OPEN INSERTURL, *INSERT ; Aliases for commands discontinued in AutoCAD 2000: AAD, *DBCONNECT AEX, *DBCONNECT ALI, *DBCONNECT ASQ, *DBCONNECT ARO, *DBCONNECT ASE, *DBCONNECT DDATTDEF, *ATTDEF DDATTEXT, *ATTEXT DDCHPROP, *PROPERTIES DDCOLOR, *COLOR DDLMODES, *LAYER DDLTYPE, *LINETYPE DDMODIFY, *PROPERTIES DDOSNAP, *OSNAP DDUCS, *UCS ; Aliases for commands discontinued in AutoCAD 2004: ACADBLOCKDIALOG, *BLOCK ACADWBLOCKDIALOG, *WBLOCK ADCENTER, *ADCENTER BMAKE, *BLOCK BMOD, *BLOCK BPOLY, *BOUNDARY CONTENT, *ADCENTER DDATTE, *ATTEDIT DDIM, *DIMSTYLE DDINSERT, *INSERT DDPLOTSTAMP, *PLOTSTAMP DDRMODES, *DSETTINGS DDSTYLE, *STYLE DDUCS, *UCSMAN DDUCSP, *UCSMAN DDUNITS, *UNITS DDVIEW, *VIEW DIMHORIZONTAL, *DIMLINEAR DIMROTATED, *DIMLINEAR DIMVERTICAL, *DIMLINEAR DOUGHNUT, *DONUT DTEXT, *TEXT DWFOUT, *PLOT DXFIN, *OPEN DXFOUT, *SAVEAS PAINTER, *MATCHPROP PREFERENCES, *OPTIONS RECTANGLE, *RECTANG SHADE, *SHADEMODE VIEWPORTS, *VPORTS EDWFX, *EXPORTDWFX EDWF, *EXPORTDWF EPDF, *EXPORTPDF -QPUB, *-EXPORT ; Aliases for commands discontinued in AutoCAD 2007: RMAT, *MATBROWSEROPEN FOG, *RENDERENVIRONMENT FINISH, *MATERIALS SETUV, *MATERIALMAP SHOWMAT, *LIST RFILEOPT, *RENDERPRESETS RENDSCR, *RENDERWIN ; Aliases for commands discontinued in AutoCAD 2009: DASHBOARD, *RIBBON DASHBOARDCLOSE, *RIBBONCLOSE ; -- User Defined Command Aliases -- ; Make any changes or additions to the default AutoCAD command aliases in ; this section to ensure successful migration of these settings when you ; upgrade to the next version of AutoCAD. If a command alias appears more ; than once in this file, items in the User Defined Command Alias take ; precedence over duplicates that appear earlier in the file. ; **********----------********** ; No xlate ; DO NOT REMOVE
Don Ireland
Engineering Design Technician
Not necessarily updated, but restored to OOTB and then extended. I've had users cart around the PGP file from many moons ago and overwrite the new one instead of appending their aliases to the end.
Right. My only point was that their CURRENT one didn't include the aliases they're trying to use.
Don Ireland
ok fixted the text thing... ddedit was no longer a command, its textedit. so i fixted my lisps and pgp's and my double click in the cui menu.
Now that all works. now if i can just get the thing to repsond quick.
i can type 10x faster than it will respond. zooming sucks, its sluggish and pauses alot. even going to pan something it does a quick pause.'
There's a command auto-complete to assist users which may be getting in the way. There should be several recent posts on how to restrict or disable it to allow faster command-line use.
Hello from France
Q1) Which Windows exactly ? Win Seven / Win 8.0 / Win 8.1
Q2) 32 or 64 bits
Q3) How much memory on your PCs in Gb ?
Q4) Which graphic Card and its driver version ?
Q5) Average size of your DWG (Main DWG + DWGs in XREF) ?
Q6) Have you a lot of Images inserted ?
Q7) Have you a lot of Annotative Objects ?
Q8) have you a lot of Dynamic Blocks ?
Thks in advance ...
Patrice BRAUD
all our pcs are win 7 64 bit with 16gb of ram 500gb hard drives at big 760gt video cards min. quad cores at 3ghz
i have all autocompletes turned off as well.
2014 didnt have this issue. Pretty sad you just update and its garbage!
Also im on AutoCad MEP 2015 and it says there are no updates or service packs for it.
Also it doesnt matter what drawing i open, i can even do a new drawing and it will be sluggish
it seems like it doesnt like any of the commands.
sometime i have to type the same command twice for it to recognize
AutoCAD MEP... that would have been helpful up front, as it is not the same as AutoCAD. It has a host of additional automation which may require some configuring; I recommend checking under the board for that product: http://forums.autodesk.com/t5/AutoCAD-MEP/ct-p/2036
Hello
A few suggestions ...
S1) Have you downloaded and installed the latest NVidia driver for your GT 760 ?
Because 2015 is very sensitive with the graphic card driver ... And the 2014/2013/2012/etc much LESS !
For example the Quadro NVidia users have to run with the v3.33 driver which has been released in May 2014
( Even waiting for a new one ... )
If you disable the graphic hardware acceleration , have you the same problem ??
S2) Please disable the Control Cycling (Ctrl W if I remember well)
S3) Maybe run with ROLLOVERTIPS = 0 & QPMODE = 0
Of course if you have an ACAD 2015 , you have installed the SP 1 !!!
If you have ONLY an ACAD MEP 2015 , you MUST wait until the SP 1 (for AA & MEP 2015) will be released !
Today this SP 1 for AA & MEP 2015 is in Beta Test ... and will include the ACAD SP 1 ...
Patrice BRAUD
The update is for plain AutoCAD, where you are posting: you did not communicate your version. Verticals come later usually for patches.
Another user, using ARCH, is also having difficulties with DDEDIT's replacement in another thread: since MEP is built on ARCH, you too should probably move to the correct forum for discussions with your peers about possible fixes too.
Be sure to report this bug to Autodesk, posting here is not the best solution:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
If you are a subscription user, you can report through the Subscription Center as well (as in do it twice). No one else is going to do it for you.
To the OP, ........This. ^^^
Do this. Otherwise, Autodesk doesn't know about it, or they know about it less.
It looks this kind of complain is quite popular whenever new version arrives. For user's interface, I would suggest new version same as the old one as default, just give the user a choice at the beginning -' We have a new interface, would you want to try?' and the default options is 'No, thanks.'
Hello
I suggest one other improvment with new releases ...
<Humour ON>
We have new features & new commands, do you want to disable them ?
Default answer is YES !
<Humour OFF>
Patrice BRAUD
<Humour ON>
<Humour OFF>
You can already do that, don't upgrade.
If you're on subscription, don't install newer versions.
To the OP and rkmcswain, This is my answer/suggestion:
Changing ddedit to textedit is quite a serious issue imo. I realy can't remember any function to stop working. After typing ucs 3 is still an option allthough not displayed anymore.
I hope they will bring back ddedit because it's to simply keep on working the way one used to.
@TS: I use d instead of dd for ddedit, it's less typing 😉
