anyone can help me please.
with i7 3.4 gHz 16gb ram
graphic card quadro 4000
autocad 2015 freeze on every modify command. expecially when I work on 3D drawing. ..The only way out from the freeze is control+alt+del
It s been long time to find the problem....but till now there is no solution.
thank you
hi, have you installed all the latest updates and service packs?
Hello
Which version and date for your NVidia Quadro 4000 driver ?
Patrice BRAUD
thank you for reply...I already update both the driver for quadro 4000 and sp2 for autocad 2015.
driver version 9.18.13.4066
hi have you tried audit, purge and scalelistedit your files? This only happen in a single file or all the files> have you tried to open in other computer with same result?
yes, i did that too...but did not help.
did try to open in other computer also but same thing happen.
some objects I can do modify without freeze. It only freeze when I try to modify centain object. and it happen only in 3D drawing.
in the begining everything oke. but when the drawing file getting heavy than one by one objects start giving me problem when I try to modify.
It can happen to one object but it will freeze when i try to modify with other object with same size, same colour, same property....
Hello
Is it possible to get a copy of your DWG ?
If YES, please explain where is/are the "bad" object(s) ?
Patrice BRAUD
Here I try to attach the sample drawing. there are two object on the drawing. The blue object is the bad one. and the grey one is not problem.
Mr. Pat,
I try to erase all objects on the drawing leave the file empty. the result the file size still 26.067kb.
Hello
Sorry I haven't too much time to study your DWG ...
But I admit that there is a probleme with this blue object !
Maybe coming from a vertical ACAD (AA, MEP, etc) or from other CAD program ?
So with EXPORT (ACIS format) then IMPORT (ACIS Format), you will get a clean (ex Blue) 3D Object !
You will find it attached to my message ... 53 Ko in DWG2004 format ...
I hope it will help you !?
Patrice BRAUD
hi, i have tried also the file. i dxfout> dxfin still the same. I tried also copy to the new files still the same. i can move the blue object i didn’t encountered any problem but once I copy it hangs me few seconds. The blue object has the problem. Please find attached. Thanks and regards.
or try to remodel the blue objects?
