AutoCAD Forum
Autocad 2015 - Format Text Style
1 REPLY 1
sitimainsolutions
20801 Views, 1 Reply
FORMAT/TEXT STYLE. Now where has this gone (last seen in Acad 2014)?!
I open a drawing where the default font settings are different and I need to reset the fonts automatically (height, width etc). Typed "TEXTSTYLE" and I got myself some strange command popping out.
The format tab has totally disappeared, right? So how do I change my text settings without going through one-by-one in Properties?! TIA
Tags (1)
1 REPLY 1
enter Style at the command line
on the ribbon you will see the Annotate tab, on the text panel use the pull down arrow to set current the desired text style.
at the bottom of that window you can also manage text styles.
”Boost
