I just upgraded from Autocad 2014 to Autocad 2015. Every .dwg file I open and save with Autocad 2015 loses its thumbnail preview in windows 7.
Thumbnail preview settings are checked in Options, THUMBSAVE is set to 1, and I have tried the popular solutions from the Autodesk Support Forums (installed DWG Trueview, made sure PreviewVisible is set to 1 in the REGISRTY EDITOR), but no joy.
I realize the thumbnail preview is not a major component of working with Autocad, but for large drawing folders the preview makes finding the correct drawing much faster.
As a note, the .dwg files are still set to save in a AutoCad 2013 drawing format (as was the case with Autocad 2014), so I don't know why upgrading to 2015 would have caused this issue with windows 7.
Solved by pendean. Go to Solution.
