Is anyone else seeing the Display Plot Styles function not working in Layouts in AutoCAD 2015? I can open the same file with the same B&W plot style setting in both AutoCAD 2014 and 2015, and even though the "Display Plot Style" box is checked in the Page Setup Manager, 2014 will display the Layout on screen correctly and 2015 will not. Both use a B&W plot style. 2014 will show onscreen correctly... 2015 will display in colors.
If I begin a brand new file in 2015 I can make this work. But it seems files that were created in 2014 won't. I should add that both versions will plot the files correctly, and they will display correctly in a preview. It just appears that they will not display correctly (in this case in B&W) onscreen in the Layouts.
Either I've missed a setting somewhere or there might really be something off here. A few independent checks by a few of you out there might help.
Thanks!
Dave.
Solved by heinsite. Go to Solution.
what happens if you set LAYOUTREGENCTL to 0 and just change from one layout to another one?
- alfred -
___
Thank you. I had the same Issue and this was the solution for me. Acad 2016
