AutoCAD Forum
AutoCAD 2015 Deployment Image on Windows Server 2003
5 REPLIES 5
Dale.Bartlett
351 Views, 5 Replies
Hi All, As the title suggests, I am attempting to build an AutoCAD 2015 deployment image on Windows Server 2003 (with full service patch/updates). I receive an error with respect to the Windows Installer. Without going into the specifics of the error, my question is whether this is possible? Given that Server 2003 is XP based, I suspect not. Whilst not officially supported, I was interested if anyone had personal experience. Many thanks (again), Dale
______________
Yes, I'm Satoshi.
5 REPLIES 5
>> [...] deployment image on Windows Server 2003 (with full service patch/updates).
It is not important where the image files are stored, but it might be necessary to have a workstation based on Windows 7 or 8,1 to start the deployment creation ... and that's what I would suggest first.
That might be the reason why there was no response yet. Whenever you have errors, let us know them, which ones they are. The more info you can give, the better (and faster) the chance will be to get the answer to your issue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
in reply to: Dale.Bartlett
WinServer 2003 is dead just like WinXP.
WinServer OS are not supported for AutoCAD as well.
Why are you running a server OS as a desktop? There is no performance gain, and probably a handicap.
Alfred.NESWADBA
in reply to: pendean
Hi Dean,
as far as I understand the TO just want's to create a setup image on the server, not running AutoCAD on it, am I wrong?
- alfred -
Alfred NESWADBA
pendean
You are correct Alfred, my error.
Dale.Bartlett
Hi All, Thanks for the responses. I also cross-posted: http://forums.autodesk.com/t5/installation-licensing/autocad-2015-deployment-image-on-windows-server... Agreed, create deployment image from a workstation is normal process and not what I was following on this occasion. Regards, Dale
______________
Yes, I'm Satoshi.
”Boost
