Hi All, As the title suggests, I am attempting to build an AutoCAD 2015 deployment image on Windows Server 2003 (with full service patch/updates). I receive an error with respect to the Windows Installer. Without going into the specifics of the error, my question is whether this is possible? Given that Server 2003 is XP based, I suspect not. Whilst not officially supported, I was interested if anyone had personal experience. Many thanks (again), Dale
Solved by Alfred.NESWADBA. Go to Solution.
>> [...] deployment image on Windows Server 2003 (with full service patch/updates).
It is not important where the image files are stored, but it might be necessary to have a workstation based on Windows 7 or 8,1 to start the deployment creation ... and that's what I would suggest first.
That might be the reason why there was no response yet. Whenever you have errors, let us know them, which ones they are. The more info you can give, the better (and faster) the chance will be to get the answer to your issue.
- alfred -
Hi Dean,
as far as I understand the TO just want's to create a setup image on the server, not running AutoCAD on it, am I wrong?
- alfred -
