Every time i open up AUTOCAD 2015 the Ribbon Defaults to the Layout tab. How do i change this out open to my home tab?
Solved by pendean. Go to Solution.
Any info on this? I have the same issue. It is extremely annoying when switching from model space to paper space and having to switch from Layout to Home each time as well.
Neither. For the original poster, it seems that each time he/she opens a file, the default workspace setting is set for their "Layout" tab on their ribbons. This is the same for me, as well as when working on a file, I switch from Model Space to my Layouts quite frequently and have it hotkeyed via macro. When I switch from model space to paper space, the Ribbon switched from my custom "Home" ribbon to a "Layout" ribbon that I do not use. Is there a system variable for this feature?
I found it under the contextural Tab States > Layout Selected. I removed it. Sorry, I must have missed it since I assumed they were all in alphabetical order.
Macro
'_setvar;tilemode;$M=$(!=,$(getvar,tilemode),1)
bound to an extra button on my mouse + shift. makes it easy to switch back and forth. only works with the most recent layout, so if you have multiple layouts you'll have to select/toggle the layout that you may be working with the most.
So you found it under the contextural Tab States > Layout Selected, but how do I find that and fix this issue? I still use AutoCAD LT 2014 because of this issue. I get so frustrated changing back to the home tab that I now refuse to use the updated versions of AutoCAD.
