In AutoCAD 2015 I can not deselect features in a solid with shift+click (either surfaces or features). ctrl+click seems to work fine.
Is this a system varible I'm missing?
Solved by GrantsPirate. Go to Solution.
Solved by simoncc. Go to Solution.
In OPTIONS/ go to Selection tab/ Then check the box for "Use shift to add to selection"
That just makes shift act like ctrl.. they both add to the selection. I would like to subtract a selection from a solid.
For example.. draw a square with the circle in it. Extrude the objects, delete the cylinder that was created. Now ctrl+click the cylinder (or hole) feature.. typically you could deselect it with shift+click, but not in AutoCAD 2015 it seems.
If you have Raster Design installed. Try running IOPTIONS command, User Preferences and untick Shift+Left click image select under Mouse Settings.
Go to your osnap options, and go to selection cycling. Make sure the box is check that states - Allow selection cycling. Then that will allow you to deselect objects while in a command, without going through the slection filter.
For what it's worth, this works in 2016 too.
I am used to using Shift+Click to remove objects. In 2016 it wasn't working even though the cursor showed a little - (minus) sign by it.
The IOPTIONS solution worked.
Thanks.
I am having the same problem and have tried suggestions in the posts above. Very frustrating as with the older versions this function worked fine.
Has anyone worked out any other tricks?
Do you have any images attached in the drawing? I had the similar issue but found the problem was because I had an image attached it would not let me deseclect items that were on top of the image even though the image layer was off.
If you want to use the deselect tool while drafting on top of the image but keep it in your drawing you need to freeze the image layer.
Hope this helps.
Cheers,
Auto cad tab
Preferences
Cursor and selection
Slection modes - make sure "use shift key to add selection" is selected
That worked for me
Using the example given earlier, pick the hole with ctrl+pick, there will be a red grip, use ctrl+pick and pick on the red, it is now blue and won't be part of the selection.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I was having the same problem after bringing an image into model space from google earth. The way to get the deselect option back to the default shift-click is to go to the raster tools tab then click the drop down arrow in the "insert and write" section at the top left . Then go to the user preferences tab. Under mouse settings uncheck the Shift+left click image select box. This gave me back the original deselect option by shift clicking. Hope this helps everyone.
my co-worker was just having this issue, after comparing our profiles I noticed "Object grouping" was on, after turning it off, it worked just fine.
