Missing Burst Terribly. Is it as simple as loading the Express Menu like in 2013? However I can't seem to locate any express menu to load....
Am I not looking in the right place?
C:\Program Files\Autodesk\AutoCAD 2015
Solved by nestly2. Go to Solution.
It sounds like you don't have Express Tools installed. If so, install Express Tools by re-inserting your installation media (or use Programs & Features in the Windows Control Panel) to "Add or Remove Features" for AutoCAD2015
MENULOAD, then browse to C:\Program Files\Autodesk\AutoCAD 2015\Support\en-us and select the acetmain.mnl.
Had to install Express Tools, thanks!
These two links helped me, in case anyone else has the issue later.
Usually it is installed as default.
Just type EXPRESSTOOLS in the command line to load it automatically.
So I just got a new PC, installed MEP 2015 for the 1st time, still no express tools loaded. At least now I know what to do.
Thanks again!
Yeah, I don't think Express Tools install on the vertical product by default, but you have the option during setup to do a "typical" installation, or a "Custom" installation. If you aren't sure go with typical, but if you know what features you do/don't need, then custom is probably the better install option.
