I have installed the new 2015 update on my home and work computers. On my work computer, connected to our network, I have a display problem in that when I select commands like trim or match properties the whole drawing goes slightly blurry making selecting objects difficult. The installation on my home machine (standalone) works perfectly fine as you would expect. Has anyone else had the same problem?
Solved by lyubo11. Go to Solution.
Solved by braudpat. Go to Solution.
I found what I was looking for here. If you don't like the new blue fuzzy line.
Thank God for all who help!!!
Here's how I fixed it:
Right click on screen and go to Options
Select the User Preferences tab
Click on the Lineweight Settings button
Set the slider on the Adjust Display Scale slider to 50%
Mine was set to about 80%, I don't know how it was set there, probably something in an update.
I installed the latest video driver first, and made all the other settings suggested, but still had blurry drawings. I thing an update caused the problem.
Stumbled across this thread looking for a silution to the dreaded 'blurries'.
Just why oh why do we need a PRESELECTION effect? No-one in our team can see it serving any useful purpose.
If the developers are that stuck for ideas why not add a PREMENU effect so that menu items are highlighted and dropdowns open depending on current movment of mouse cursor just in case that is where you are heading?
