Hello All,
I have some general questions which I can't seem to find and answer on the net.
1. I used ACAD 2009 previously and when I double clicked a line/circle, the Properties Box opened. In ACAD2014, the Quick Properties Box opens. Can I change it NOT to open the Quick Properties and just open the standard Properties Box?
2. When double click on a Dimension in A2014, it shows me to edit the text in that dim. A2009 the Properties Box opened. Can I change this so it works like 2009?
3. When I create a dim a2014 and it is NOT centered/aligned, it does NOT show using right-click like a2009 to HOME/center the text.
Please ask if more questions are needed. Sorry for being vague on my questions.
Thank you & Best Regards
KenJG - ACAD2014
Solved by pendean. Go to Solution.
Solved by Bob_Zurunkle. Go to Solution.
Ummm couldn't you turn off Quick Properties? i am at work, so I only have 2013 to reference -- but there is a toggle on the bar at the bottom of the screen (the tooltips should identify which is QP). Alternatively, ctrl-shift-p should bring up QPMode. That toggles it on and off.
For #3, select the dimension & hover over the text grip. See if the option you need is in the multifunctional grip menu.
