Okay I reworke our toolbar button images years ago (2008 or so) and they have worked flawlessly ever since until now.
I just loaded 2014 onto a new computer and poof every custom toolbar has a question mark. Yet the image displays on the preview in the cui.
Anyone else experience this or know what needs to happen?
A little more info.
All of my button images are in a folder on my C: drive and that path is in the support file search path.
Ok.. as I was typing this I had an idea so I tried it and it worked. I thought I would post here in case anyone else comes across this.
I went to one of the buttons and click on the small and large image and browsed to the folder with the BMP files and clicked it for both small and large.. And when I clicked 'ok' everything started to display correctly. Makes no sense at all maybe it's a bug?
Solved by sssteve72. Go to Solution.
I had a similar issue with 2014... as I recall I manually loaded the previous MNR. I'm not sure why the custom icons are not stored inside cuix files.
