Hello there!
I've just downloaded AutoCAD 2014 Student Version, and I can't seem to make my status bar on the bottom work. It's pretty annoying, as I couldn't manage to find the solution yet, did the access path to it changed compared to previous versions?
It's just blank grey (where OSNAP, DUCS, and other fun stuff's icons should be).
I would really appreciate your help!
Cheers!
Just to make sure: the screenshot points to an area where those switches like OSNAP, Dynamic UCS (and the other fun stuff) is not to be found, you pointed to the drawing statusbar whereas those switches are in the application statusbar ==> that is lower than the command line area ... but not shown on your screenshot.
- alfred -
I know, that it should've been under my command line, but it didn't show up at any resized window state (and I didn't crop the image just to make this thread...).
Since then I reinstalled it, that fixed the problem, but I'm still wondering, what the problem was, as it never happened to me before.
I use AUTOCAD 2013, but when I set my STATUSBAR to 1, I got all my toggle command back. Thanks.
