AutoCAD Forum
AutoCAD 2014 - Rotate vertical linear dimension text to 0 degrees (horizontal)
2 REPLIES 2
3124 Views, 2 Replies
I'm having trouble trying to rotate the text of a vertical linear dimension to read horizontally.
When I type in 0 degrees using the text angle tool in the dimension panel it returns the text to it's default position of 90 degrees. I tried 360 degrees, but encountered the same result.
Any help much appreciated.
Steve
Tags (2)
2 REPLIES 2
doben
It should work if you change the rotation to 359.999
in reply to: doben
Thanks doben.
Seems like a bit of a fudge to me, but if that is the way it is done so be it.
”Boost
