I'm having trouble trying to rotate the text of a vertical linear dimension to read horizontally.
When I type in 0 degrees using the text angle tool in the dimension panel it returns the text to it's default position of 90 degrees. I tried 360 degrees, but encountered the same result.
Any help much appreciated.
Steve
Solved by doben. Go to Solution.
