AutoCAD Forum
Autocad 2014 internal apps not working but work on my 2013 version
8 REPLIES 8
Message 1 of 9
XlhHarley
326 Views, 8 Replies
Afternoon
I have one machine in my group of 11, that the internal Autocad applications are not working.
Example.. I open the layer dialogue box and right click on the layer name, go to make my layer not appear ina all view ports and "function not found"
Example..  start a new drawing go to paper space, type in MVSETUP... command MVSETUP not found.
I have contacted Tech support and have followed thier advice and - still not working. (even a new install - but not  a fresh one)
If I was a betting man, (or person), I would think it has something to do with this new secuirty crap that was part of 2014..and some minute switch that is turned "off" in my setting,  as when I  re- install 2013 on the same machine it all works with now problem
Has anybody else run into this?
8 REPLIES 8
Message 2 of 9
pendean
in reply to: XlhHarley
Try the simpler fix of just resetting AutoCAD: it is one out of 11 that otherwise work.
Message 3 of 9
XlhHarley
I have reset
I have reinstalled
i have upgraded (after I re -installed 2013).
I have grabbed another users profile from a working machine and imported in to the new machine
It still ends up being works 2013 but not the 2014 software
very confusing
Message 4 of 9
pendean
What's unique about your PC compared to others?
Did you use the 'migrate' option before using 2014?
Message 5 of 9
XlhHarley
7 of the machines are the same make - model etc..etc..etc
purchased the same time
All are running the same third part applications -
the only difference is this machine is running the design suites premium version autocad and not staright autocad if that makes a difference.
I have discovered that that if I go in and actually run MVSETUP by launching the application it will run until that machine restarts Autocad, I have looked at the file paths and they are pointing to the location of the applications
i need a beer
Message 6 of 9
pendean
Are you actually running plain AutoCAD? Or one of the verticals "as AutoCAD"?
Message 7 of 9
XlhHarley
Running plain autocad _ I am under the impression that it is just the way it was bundled and sold.. you get more for less
Message 8 of 9
pendean
Ha! you wish life was that simple to blame it on 🙂
Message 9 of 9
pothied
in reply to: pendean
If you have tried everything else, then I would recommend a clean install of the product. You can find the instructions for that here:
http://knowledge.autodesk.com/article/How-to-remove-all-Autodesk-products-from-a-Windows-system
David Pothier
”Boost
