If autocad is running when I unlock my computer it will freeze. It still lets me close out and save my work, but I am unable to do anything else in the program. Sometimes it will crash my video driver recover then allow me to continue working.
Try checking for a newer (different) video driver and/or switch to a Windows Classic theme (non Aero theme)
this is the problem or it could be the graphics card itself
try different graphics card drivers like stated above
DarrenP
I have upgraded my graphics driver already. I have had 2014 for some time now and no driver update has helped. There was no problem when I had autocad 2013.
I disabled aero theme and the problem remained. Autocad is fully up to date.
I have had this problem also. I found that when it it "Frozen" there is a message window in the background that says the Hardware Acceleration was going to be turned off. When I clicked OK to this. I was able to continue working with no problems. I tried the same things that you have, but nothing worked, but I haven't had that problem in a while.
