AutoCAD Forum
Autocad 2014 - Fatal error on etransmit
47 REPLIES 47
Message 1 of 48
ruipfbarreiros
10051 Views, 47 Replies
Everytime I try to use the etransmit command, i get fatal error. This didn't happen with the previous version of autocad, it only started happening once I installed v14.
Ever happened to you?
Using Building Design Suite 2019
47 REPLIES 47
Message 21 of 48
kevlor
in reply to: kivist
make sure you put replacement files in correct folders.
make sure to restart computer.
Message 22 of 48
Until a fix is issued by Autodesk, here's a workaround that has so far worked for us when the 2014 Civil 3D OE is installed. Close AutoCAD, if open. Go into the folder C:\Program Files\Autodesk\AutoCAD 2014 and rename the file "AeccETransmit.dbx" to "AeccETransmit.dbx.old". Please note that you may need admin rights in order to accomplish this change since the file resides in a program folder. Once renamed, open AutoCAD and give Etransmit another try.
As with any change to a file, please test to make sure all is working as expected. We tried AutoCAD 2014 SP1 before making this change, but as others have discovered it did not resolve the issue. This is not a fix posted by Autodesk, so please test as needed.
Message 23 of 48
jneal
in reply to: kevlor
I just tried the above with no luck. Still crashing on Etransmit in Map 2014-
Application Engineer
All CAD Northwest
Meridian ID
Message 24 of 48
kevlor
in reply to: kevlor
Here is the workaround that I have found:
  1. install autocad 2014
  2. install C3d object enabler
  3. type APPLOAD at comand line
  4. click "contents" under startup suite
  5. click "add"
  6. add the following files to startup suite:
aeccivilbase.dbx
aeccland.dbx
aeccmapcheck.dbx
aeccnetwork.dbx
aeccparampart.dbx
aeccplanprod.dbx
aeccpointcloud.dbx
aeccpressurepipes.dbx
Maybe this will work for others.
Message 25 of 48
jpCADconsulting
in reply to: kevlor
Thanks, this was a real stumbling block towards using 2014 here.
FYI, I added the following lines to my acad.lsp.  Seems to be working smoothly.
(arxload "aeccivilbase.dbx")
(arxload "aeccland.dbx")
(arxload "aeccmapcheck.dbx")
(arxload "aeccnetwork.dbx")
(arxload "aeccparampart.dbx")
(arxload "aeccplanprod.dbx")
(arxload "aeccpointcloud.dbx")
(arxload "aeccpressurepipes.dbx")
The other option (renaming the arx file) also worked, but would be more difficult to implement office wide.
Message 26 of 48
Mike.Lapinski.SG
in reply to: kevlor
Looks like an updated Civil 3D Object Enabler for AutoCAD 2014 has been released which will hopefully resolve this issue once and for all. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825057&linkID=9240618
Message 27 of 48
RICHARDGILBERT6417
in reply to: kevlor
Has anybody tested and confirmed?  It would be nice if the latest file had version notes indicating that it resolved that specific issue, before I start burning hours just to find out it isn't a new version and doesn't solve anything, and then end up having to uninstall and reinstall my entire ACAD 2014 again.  I guess I am saying that at this point in the experience I am lacking a ceretain level of trust. For this expensive of a software product, I think the support on this has been dismal, and I may as well get a competitor's product if that is the best they can do.
Message 28 of 48
I plan on testing today and will post my results.
Message 29 of 48
kevlor
in reply to: kevlor
I'm going to wait to see if anyone says that the new OE works. My workaround has the problem fixed for now and I don't want to break it.
Message 30 of 48
RFUSE
in reply to: kevlor
You might want to hold off on the Autodesk fix.  Looks like it crashed my ACAD 2014 and now I have to reinstall it. "Repair" failed.  I should have heeded the fact that when installing the fix it indicated that it was "untested"!!!  Wonderfull.  .  .
Used 2013 to publish a project that had to go out.
It's time to go back to 2013 until 2014 is stable.
Lesson learned many versions back - NEVER EVER remove the "olde" version!
R
Message 31 of 48
jpCADconsulting
in reply to: RFUSE
Odd. On first tests in AutoCAD Architecture (32bit and 64bit) with sp1
installed it seems to work well.
Will be able to test on vanilla AutoCAD next week and will post results.
Read the earlier posts in this thread for a solid workaround.
Message 32 of 48
I would ask for a show of hands from those who want their $5,000 software to work without a workaround, but I would hate to flood the thread.
Message 33 of 48
elong
in reply to: ruipfbarreiros
When we try to run the etransmit command using AutoCAD 2014LT on one of our HP 420 Windows 7 64bit machines it crashes without fail. I have added the service pack and the Graphics hotfix. It still does not work.
Message 34 of 48
kevlor
in reply to: elong
Has anyone had a good testing of this new OE yet?
Message 35 of 48
jpCADconsulting
in reply to: kevlor
Yeah.
I have it on AutoCAD architecture and vanilla AutoCAD and it seems to
resolve the issue.
Read earlier in the post for a solid workaround if it does not work for you
though.
Message 36 of 48
elong
in reply to: jpCADconsulting
I uninstalled the Civil Object enabler, then uninstalled and re-installed AutoCAD on that computer. and it works fine now.  Thank you.  Elizabeth
Message 37 of 48
kevlor
Did you reinstall the Civil Object enabler?
Message 38 of 48
cado
in reply to: kevlor
do nothing for me..
all updated, OE removed,...HF made..
etransmit still crash autoCad.
Message 39 of 48
cado
in reply to: Mike.Lapinski.SG
Yes ! This step made it.
C:\Program Files\Autodesk\AutoCAD 2014\AeccETransmit.dbx.old
thank you very much.
Message 40 of 48
SleepingLady
in reply to: kivist
New Civil 3d object enabler fixes the e-transmit problem with autocad. Civil3D_2014_OE_64Bit_SP1
”Boost
