AutoCAD 2013/2014/2015
Active Member
jpedersen
Message 1 of 35 (39,995 Views)
Accepted Solution
AutoCAD 2014 drawing tabs and command line missing
39995 Views, 34 Replies
08-14-2013 06:19 AM
Morning All,
The last three times I have started my ACAD 2014 the drawing tabs are gone. Any suggestions?
Also, my command line is missing and all I see when I hit my F2 is my previous entries except for the current entry. Any suggestions on this one?
Any help would be great!
AutoCAD 2014
Navisworks Freedom-Sim-Manage 2014
Autodesk Plant 3D Design Suite Ultimate 2013
Distinguished Mentor
nrz13
Message 2 of 35 (39,977 Views)
Re: AutoCAD 2014 drawing tabs and command line missing
08-14-2013 07:39 AM in reply to: jpedersen
Drawing tabs (file tabs) are controlled by entering FILETAB and FILETABCLOSE at the command line.
The command line is toggled on and off with the Ctrl+9 keyboard shortcut.
I"m not sure why they suddenly disappeared on you, but hopefully they'll stick around after getting them back on.
______________________________________________________________________________________________________________________________________________________
System specs: AutoCAD 2015 64-bit SP1, Windows 7 64-bit SP1, Intel Core i7-2600K, 16GB RAM, Crucial M4 SSD, AMD FirePro V4900, 2 Dell Monitors (2560x1600)
*Expert Elite*
Charles_Shade
Message 3 of 35 (39,953 Views)
08-14-2013 11:31 AM in reply to: jpedersen
Welcome to the Autodesk Forums!
As mentioned above and save your WORKSPACE.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Member
jpedersen
Message 4 of 35 (39,944 Views)
08-14-2013 12:10 PM in reply to: nrz13
FILETAB worked - thank you.
CTRL + 9 did not work. . .
AutoCAD 2014
Active Member
jpedersen
Message 5 of 35 (39,940 Views)
08-14-2013 12:11 PM in reply to: Charles_Shade
thank you.
I have my workspace settings set to always save changes.
CTRL + 9 did not work...
any other suggestions?
AutoCAD 2014
nrz13
Message 6 of 35 (39,940 Views)
08-14-2013 12:12 PM in reply to: jpedersen
The command line controls for the command line visibility are COMMANDLINE and COMMANDLINECLOSE.
*Expert Elite*
nestly2
Message 7 of 35 (39,928 Views)
08-14-2013 12:42 PM in reply to: jpedersen
I would recommend manually saving your workspaces rather than saving them automatically because it's too easy to inadvertently save unwanted changes, as may have happened here.
Your command line may be off-screen.  If so, you should be able to restore it to it's original position in the CUI.  Select the workspace, then expand "Palettes" and select "Command Line" in the right panel, then edit it's properties in the lower right panel (Show = Yes / Orientation = Bottom)
Here's a demo -->  http://www.screencast.com/t/kvsIb70dSk
Active Member
jpedersen
Message 8 of 35 (39,917 Views)
08-14-2013 01:17 PM in reply to: nestly2
going into the CUI was the trick!
Thank you.
AutoCAD 2014
Active Member
jpedersen
Message 9 of 35 (39,917 Views)
08-14-2013 01:19 PM in reply to: jpedersen
Thank you all for your help...its nice knowing you can ask for help and get this many replies back in less than a day! Hope I can help one of you out sometime.
Now get back to drawing some polylines!!
AutoCAD 2014
mazikhelela
Message 10 of 35 (32,234 Views)
02-10-2014 07:57 PM in reply to: jpedersen
Filetab does not work for me
Announcements
Need installation help?
