Morning All,
The last three times I have started my ACAD 2014 the drawing tabs are gone. Any suggestions?
Also, my command line is missing and all I see when I hit my F2 is my previous entries except for the current entry. Any suggestions on this one?
Any help would be great!
Solved by nestly2. Go to Solution.
Solved by nrz13. Go to Solution.
Dear Sir,
Thanks a lot for your quickly reply. I have got your sended drwings as good there is other lines forexample much elbows with redlines, not my draws it is ok i am happy get back my drawing and i appreciate to you for this. but still i can not recovering fallowing your says. Because if i can recover my drawings with this option i will recover some other my drawings like attached other . I thing i will remove my autocad 2014 trial verison and format my p.c after that i will install all programs again . There is no looking otherway because i nstalled 2007 and 2010 versions but nothing happen changed. Please recover last my lost drawings attached than after i won't do discomfort you. I will format to all. Thak you for everything from now.
respectfully.
B.A.E
Go to ADCENTER and I insert all the blocks that is in this drawing, not much in there that can be used.
Try to click the waorkspace switching button at the bottom right corner.
then select the workspace of your choice there.
See attachment
Hi all,
can someone help me with this? The command line is really big and the other icons in the corners are so small I can barely read them...
thnx
Dear j_tybrghien,
Your command line looking leaved from the it's place. Please try, keep command line with left mouse button from lef corner point and move command line than you can put comment line to the any where at the command place or work display. I hope help to you
Bayram Ali EREN
Hi all
I'm having some trouble with something for school. We have to make a roof like in the example and I have no idea how to even begin with that...
Could someone help me out?
Thank you!
Dear j_tyberghien ,
Sorry! about for couldn't help about 3D drawings. I am so sorry! I think you nned have to more experts someone.
B.A.E
I am also having the same issues with the command line. When i follow the instructions in the video and go to the workspaces tab there is nothing inside of it. Any other suggestions for getting the command line restored?
I have the same issue. Tried Ctrl+9, doesn't work. Any other suggestions? it says that it closes the window, but there is nothing that I can see either closing or opening... I don't need it in most cases except when I am measuring things and need to see the values and it is quite frustrating when it is missing the info.
TIA
Hi, I just saw your post (the forums have been having problems with notifying users of new posts). Were you able to get it figured out?
When you say "it says that it closes the window", what exactly is "it" that is telling you that? As a workaround, you could use dynamic input (F12). Otherwise, post a screen shot when it's on so we can try to see what's going on.
If you can't use the F12 toggle, you can enter DSETTINGS on the keyboard (should work even if you can't see your command line). Then select the Dynamic Input tab and configure as desired.
