I recently updated AutoCAD from 2013 to 2014. In 2014 I do not have my command line docked but it is placed on the bottom edge of the drawing screen. When AutoCAD is closed and reopened again the location of the command line jumps to the middle of the screen. This also happens when I use the Plot command or whenever all the drawings are closed but AutoCAD is still open. Even after saving the workspace it does not save where I have placed the command line.
The picture attached shows the default location for the command line. No matter how many times I move the command line it always opens there.
Is there a specific way to lock the placement of the command line on the screen and save it for whenever I reopen AutoCAD? I beleive I have looked through all the options and settings and I am still not seeing anything to do so.
Thank you
Solved by nestly2. Go to Solution.
Mine stays put in 2014 when docked, haven't tried undocked.
Is sys. var. LOCKUI set to zero?
Stupid question time: are you actually using the workspace you are saving?
I've seen this before and I believe your Command line is technically "docked left". which will cause it to re-center on the left edge everytime you re-enter the workspace. Pull it away from the left edge and.or change it's status in the CUI to "floating"
