AutoCAD Forum
autocad 2014 cannot display Base View
19 REPLIES 19
Message 1 of 20
sharonchan
2128 Views, 19 Replies
I have been using AUTOCAD 2014 under DESIGN SUITE that is bundled with AUTOCAD Mechanical 2014. The problem is that after creating 3D model in AUTOCAD 2014, when I try entering the Layout tab, all the icons such as base view, etc do not appear as shown in the print screen attachment.  Please let me know what steps can I take to allow the standard icons to be reinitiated? Thank you.
Best Regards.
D W Lee
Singapore
Tags (1)
19 REPLIES 19
Message 2 of 20
ukdxb012
in reply to: sharonchan
Did you try just creating a New Layot via the first tool on the Ribbon? Once created, hopefully this should give you the additional functionality you require 🙂
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 3 of 20
Soyoung.H
Hi Sharon,
Normally, layout viewports tab is activated when you are in layout(paper space).
Can you check if you switch to layout the ribbon tab is activated?
Soyoung.H
Message 4 of 20
sharonchan
Hi Soyoung H.,
Yes, it is paper / Layout space and the base view persistently does not
appear...
If you require any further clarification, please do not hesitate to contact
the undersigned.
Best Regards
for Apexis (S) Pte Ltd
LEE Dah Wei
No. 21, Bukit Batok Crescent
#24-83, Wcega Tower, Singapore 658065
Tel: +65-6659-9919
Fax: +65-6234-2590
From: Autodesk Community [mailto:community-no-reply@autodesk.com]
Sent: Monday, 22 September 2014 9:58 AM
To: sharonchan
Subject: Re: autocad 2014 cannot display Base View (Autodesk Community
Subscription Update)
Hi sharonchan,
Soyoung.H (Product Support) posted a new Reply in AutoCAD 2013/2014/2015
on
09-21-2014 06:57 PM:
_____
splay-base-view/m-p/5288385#M61049>
Hi Sharon,
space).
lithium.com?subject=Re:%20autocad%202014%20%20cannot%20display%20Base%20View
> | Accept as Solution
tion=autodesk.prod%7C60f90f62%7C667b9dc1-3fca-46b9-9f2e-fa87d9ef217d&dest_ur
l=http%3A%2F%2Fforums.autodesk.com%2Ft5%2Fautocad-2013-2014-2015%2Fautocad-2
014-cannot-display-base-view%2Fm-p%2F5288385%23M61049&ticket=Hw_aYvsVYJNL_25
24961> | Give Kudos
tion=autodesk.prod%7C37010dfb%7C32b84cf6-a507-4537-8514-20b7908ceb81&dest_ur
24961>
_____
Autodesk Community sent this message to sharonchan@apexis.com.sg.
You are receiving this email because a new message matches your subscription
to a topic.
To control which emails we send you please go to, manage your subscription
& notification
settings or unsubscribe
-message-tracking/I0D5ZD2LRIYVN2> .
Message 5 of 20
GrantsPirate
Switch to the workspace 3D Modeling or add the Create View panel to your 2D workspace.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 20
Soyoung.H
When you launch AutoCAD under Mechanical, Civil 3D, etc. you may have only two panels in layout ribbon tab.
To add VIEWBASE ribbon panel, please check this article.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
I also added a video link for you.
https://screencast.autodesk.com/Main/Details/8ca52128-2eef-41d2-baed-f100d39302bb
Soyoung.H
Message 7 of 20
sharonchan
in reply to: Soyoung.H
Hi Soyoung,
Thank you for your good assistance, after following your advice, I had managed to incorporate the missing icons in the necessary BASE VIEW ribbon.
However,  a new problem has emerged. When I clicked on to the BASE VIEW icon, it keps prompting me with  "MOVE Select objects: " in the COMMAND line. Nothing from the Model space will appear wherever I try to click on. It seems that this function cannot detect any 3D drawing I have created in the MODEL space. Please help me to resolve this problem.
Thank you!
Message 8 of 20
Soyoung.H
Please click F2 button and check which command was actually executed.
Soyoung.H
Message 9 of 20
Soyoung.H
You got this?
Testing has shown that this only is reproducible with drawings/models that have been exported from products same and/or similar to Autodesk Inventor.
To work around this behaviour the drawing needs to be exported to a pure AutoCAD file, using the command -EXPORTTOAUTOCAD.
See the product documentation to this command under the following link:
Soyoung.H
Message 10 of 20
sharonchan
Still can't work:
ening an AutoCAD 2013 format file.
Regenerating layout.
AutoCAD menu utilities loaded.*Cancel*
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk
application or Autodesk licensed application.
Command:
Command:
Command:
Command: _VIEWBASE
Inventor Server failed to load.
Command: _M MOVE
Select objects: Specify opposite corner: 0 found
Select objects: Specify opposite corner: *Cancel*
0 found
Select objects: *Cancel*
Command:
Regenerating model - caching viewports.
Command: -EXPORTTOAUTOCAD
File format: 2013
Bind xrefs: Yes
Bind type: Insert
Filename prefix: ACAD-
Filename suffix:
Export options [Format/Bind/bind Type/Maintain/Prefix/Suffix/?]
filename>: 10inch
Invalid option keyword.
filename>: F
Enter file format [r14/2000/2004/2007/2010/2013] <2013>:
filename>:
Export drawing name flanges\ACAD-14-09-22, 2500lb, 10 inch mould, 3D.dwg>: *Cancel*
Command:
Command: _open
Command: *Cancel*
Command: *Cancel*
Command:
Restoring cached viewports - Regenerating layout.
Command:
Command:
Command: _VIEWBASE
Command: _M MOVE
Command: *Cancel*
the undersigned.
Best Regards
LEE Dah Wei
Tel: +65-6659-9919
Fax: +65-6234-2590
Message 11 of 20
Soyoung.H
Can you do me a favor?
Please create a new drawing and draw a box and then create the Base view.
I want to know this is your drawing file issue or program itself.
Soyoung.H
Message 12 of 20
sharonchan
Hi Soyoung,
Yes, I followed your advice and did the 3D box, the same result appeared :
Command:
Command:
Command: _WSCURRENT
Enter new value for WSCURRENT <"Drafting & Annotation">: 3D Modeling
Command:
No canvas exists. Please click New Canvas.
Command:
Command: _box
Specify first corner or [Center]:
Specify other corner or [Cube/Length]:
Specify height or [2Point]:
Command: *Cancel*
Command: *Cancel*
Command:
Command:
Command: _.erase 1 found
Command:
Command:
Command: _VIEWBASE
Command: _M MOVE
the undersigned.
Best Regards
LEE Dah Wei
Tel: +65-6659-9919
Fax: +65-6234-2590
Message 13 of 20
GrantsPirate
Probably you need to install an update, see this..
http://forums.autodesk.com/t5/autocad-2013-2014-2015/viewbase-inventor-server-failed-to-load/m-p/460...
GrantsPirate
EXPERT ELITE MEMBER
Message 14 of 20
Soyoung.H
in reply to: GrantsPirate
Have you tried the upper(GrantsPirate's) suggestion?
Soyoung.H
Message 15 of 20
sharonchan
Hi Soyoung,
After spending more than an hour I could not find that folder and the dll
file...
the undersigned.
Best Regards
LEE Dah Wei
Tel: +65-6659-9919
Fax: +65-6234-2590
Message 16 of 20
Soyoung.H
I just want you to update your AutoCAD Mechanical 2014 to the latest version,
http://knowledge.autodesk.com/support/autocad-mechanical/downloads/caas/downloads/content/autocad-me...
And you may want to try reinstallation.
Soyoung.H
Message 17 of 20
sharonchan
Dear Soyoung,
Thank you for your good support. Please let me know is my product design
suite is version 32 bit or 64 bit? Please see attached.
the undersigned.
Best Regards
LEE Dah Wei
Tel: +65-6659-9919
Fax: +65-6234-2590
Message 18 of 20
Soyoung.H
Please check your system type.
Soyoung.H
Message 19 of 20
sharonchan
My System:
WINDOWS 8.1
VERSON 6.3 (BUILD 9600)
2013 MICROSOFT
It does not state 32- or 64- bit.....
the undersigned.
Best Regards
LEE Dah Wei
Tel: +65-6659-9919
Fax: +65-6234-2590
Message 20 of 20
nestly2
”Boost
