HELP! there's "audit-bad-layer" in the layer properties manager tat can't be deleted and I can't copy/block/wblock any thing from this drawing....
the drawing become 26,888KB and growing bigger as I work on it.
Even if I delete every item in the drawing and purge it, it will still be so big.....
What can it be done????? or else I have to redraw all the drawing I receive.....
Attached the drawing that i had deleted but the "audit-bad-layer" are still in it.
Thanks you
You need to use this on your file(s):
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hot...
