AutoCAD Forum
AutoCAD 2014 and Windows 8.1
35 REPLIES 35
Message 1 of 36
99068 Views, 35 Replies
Hello everyone,
Recently I have upgraded my Windows 8 OS to 8.1. Before it, AutoCAD 2014 was working fine, without problems. But once the Windows upgrade was finished it  is impossible to run AutoCAD. When in loading screen, AutoCAD crashes. Does "AutoCAD Service Pack 1" or "Model Documentation Hotfix for 64-bit Windows 8.1" solve my problem? If not, there is any hotfix or AutoCAD upgrade to improve compatibility between AutoCAD 2014 and Windows 8.1? I have spent for hours looking for help in Autodesk web unsuccessfully.
Thanks for all.
35 REPLIES 35
Message 21 of 36
uninstalling ms visual c++ 2008 does not work. I've got an idea. How about autodesk opening 2015 for student downloads and upgrading all the windows 8.1 paid users???????
Message 22 of 36
@Anonymous What I did, I uninstalled all types of Microsoft Visual C++ (all have the year 2008) and now it's working fine and no trouble.. try it..
Message 23 of 36
in there are many verisions of visulc++ installed due to games what i have to do
Message 24 of 36
Message 25 of 36
Message 26 of 36
dharen
Recently I have upgraded my Windows 8 OS to 8.1. Before it, AutoCAD 2013 and 3d max 2014 was working without any problems. But while Windows upgrade was finished it  is impossible to run AutoCAD. When in loading screen, AutoCAD crashes. how can i run it like previous
Message 27 of 36
594625
in reply to: pendean
I am afraid that that is not the case.
I have Windows 8.1 64bit. I have tried to install both the 64 and tried the 32 (just in case).
Autocad 2015 has the following error (attached);
This is an Autocad error in this instance, and not Windows, as I am fully able to download and install any and all programmes that have Windows 8.1 compatability.
Message 28 of 36
monkywilly
in reply to: 594625
Yo tuve que volver a restaurar mi PC a windows 8 y se instalaron todos los
autocad (autocad14 , autocad arquitectura 14/15-Revit)- perfectamente.
Windows 8.1 no es compatible con ninguno de los mencionados.
Message 29 of 36
 when patching the xforce.. "could not debug privilege! are you admin?" help pls! i need to learn cad2014. Thanks in Advance
Message 30 of 36
sir my problem when patching "could not debug privilege are you admin?" how could i solve this problem..THANKS IN ADVANCE
Message 31 of 36
Message 32 of 36
http://xinyustudio.wordpress.com/2014/01/20/installation-of-autocad-in-windows-8-8-1-failure-and-sol...
This solution is really juicy! 🙂 just overwrite the setup.ini file and that's enough.
Message 33 of 36
EJbilayon
hi i have a problem same as yours..i've tried to delete the microsoft visual C++ 2008 of all kinds.. and it did not work.. AUTOCAD still fail to launch,, Please help me to find solution..thanks
Message 34 of 36
Message 35 of 36
Emmsleys
Autodesk 2016–2015 products
Most Autodesk 2016–2015 products are supported on Windows 8 and 8.1. See the system requirements for your product to verify compatibility and specific details.
Autodesk 2014 products
See the system requirements for your product to verify compatibility and specific details (for example, some products are supported on the 64-bit version of Windows 8 but not the 32-bit version).
Unless noted otherwise in the system requirements for an individual product, Autodesk 2014 products are supported on the Windows 8 operating system.
Autodesk 2013 products and older
Note: Unless indicated otherwise, this information applies to the 2013-2011 versions of all Autodesk products. Autodesk product versions of 2010 and earlier are no longer supported and are not included in considerations of Windows 8 compatibility.
Autodesk intends to support many of our key products on Windows 8 and will add additional products to the list of products supported on Windows 8 as updates and future versions are released. Product Support will provide its best effort to assist customers who have issues with products that are not currently supported.
The Autodesk products listed below have been tested and are confirmed as working correctly on Microsoft Windows 8 operating system:
If any new updates or information is made to the above list I will try my best to post in this thread.
Happy posting
Sarah Emmsley
Technical Support Specialist
Message 36 of 36
Well, what you need to do is running xforce 32 bit or 64 bit as your administration.
Good luck
”Boost
