since I have Windows 8.1 I try to use Autocad 2014, that has native support, but when I save in Autocad 2007 format I receive a message like that in the image below.
Where I could find information about retrocompatibility of Autocad 2014? There some known issues in saving Autocad 2014 in previuos format like 2011 o or 2007 format?
What about object enablers?
Thank you for your help.
Federico
Yes, all objects that are new AutoCAD releases may be not displayed correctly in older AutoCAD's. Most of the objects are converted to be at least visible/plotable in older AutoCAD's, but you should not do any modifications to that.
You can try command -EXPORTTOAUTOCAD, choose the format you like to save your drawing back (e.g. DWG2007) and let AutoCAD convert those objects down.
- alfred -
