I am presently running OS XP and I have 2010 AutoCAD. If I install Windows 7 or 8 in 32 bit version - will my 2010 work? Also if I install 2014 on 32 bit version - will that work?
Solved by hmsilva. Go to Solution.
Hi apanbasu.
Red is a nice color...
You can always consult the System Requirements from Autodesk.
AutoCAD 2010, should run on Windows 7, but not on Windows 8
AutoCAD 2014, should run on Windows 8, but there are some issues on Windows 8.1...
HTH
Henrique
@apanbasu wrote:
I had a hard time reading on the deafuklt color. so, I changed the color.
If 2019=0 is Ok with 7 - then I have to get a code from Autodesk during my installtion. I still need 32 Bit version of 7 - am I correct?
apanbasu,
again from the Autodesk System Requirements, both should run on Windows 7, 32 or 64 bit, you have to install AutoCAD 2010/14 version 32/64 0n OS 32/64...
Henrique
